How to enable 12bit for STM32F103
I’m trying to use STM32F103C8 with EmonLib. STM32 has 12bits ADC. It would be good to use it.
I tried to enable it by using setup parameter
analogReadResolution(12);
However, it does not fly. I got an error
'analogReadResolution' was not declared in this scope
Seems that this command works only for Arduino Due.
I tried to change default resolution in the library Emonlib.h.
// to enable 12-bit ADC resolution on Arduino Due,
// include the following line in main sketch inside setup() function:
//  analogReadResolution(ADC_BITS);
// otherwise will default to 10 bits, as in regular Arduino-based boards.
#if defined(__arm__)
#define ADC_BITS    1̶2̶    10
#else
#define ADC_BITS    1̶0̶    12
#endif
Is it enough?
See STM32duino+emonlib - strange behavior - #4 by Robert.Wall
