Home emoncms graphs not updating
I have emoncms running on my emon-base at home. It has run fine for a few weeks, but now it appears the graphs have stopped updating as of yesterday, but the Feeds page is showing updates every few seconds.
What should I do to diagnose this?
J.
I see that my /home/pi/data partition is full. Have I done something wrong? Is there something I probably should be doing to avoid this?
pi@emonpi(rw):~$ more /etc/fstab
tmpfs           /tmp            tmpfs   nodev,nosuid,size=30M,mode=1777 0  0
tmpfs           /var/log        tmpfs   nodev,nosuid,size=50M,mode=1777 0  0
tmpfs           /var/lib/dhcp   tmpfs   nodev,nosuid,size=1M,mode=1777 0  0
tmpfs           /var/lib/dhcpcd5 tmpfs nodev,nosuid,size=1M,mode=1777 0  0
tmpfs           /var/lib/openhab tmpfs  nodev,nosuid,size=40M,mode=1777 0  0
proc            /proc           proc    defaults 0 0
/dev/mmcblk0p1  /boot           vfat    defaults,noatime,nodiratime 0 2
/dev/mmcblk0p2  /               ext4    defaults,ro,noatime,nodiratime,errors=remount-ro 0 1
/dev/mmcblk0p3  /home/pi/data   ext2    defaults,rw,noatime,nodiratime,errors=remount-ro 0 2
pi@emonpi(rw):~$ df -m
Filesystem     1M-blocks  Used Available Use% Mounted on
/dev/root           3410  2293       952  71% /
devtmpfs             481     0       481   0% /dev
tmpfs                486     0       486   0% /dev/shm
tmpfs                486    50       437  11% /run
tmpfs                  5     1         5   1% /run/lock
tmpfs                486     0       486   0% /sys/fs/cgroup
/dev/mmcblk0p3       194   183         2 100% /home/pi/data
tmpfs                 40     7        34  17% /var/lib/openhab
/dev/mmcblk0p1        60    22        39  37% /boot
tmpfs                  1     0         1   0% /var/lib/dhcpcd5
tmpfs                 50    22        29  44% /var/log
tmpfs                 30     1        30   1% /tmp
pi@emonpi(rw):~$
Hi @jasonnet,
Your /home/pi/data filesystem being full will be the culprit.
But it does look quite small though. I have an Emon hub and have:
pi@emonpi(ro):data$ df -h /home/pi/data
Filesystem      Size  Used Avail Use% Mounted on
/dev/mmcblk0p3  3.5G  217M  3.1G   7% /home/pi/data
pi@emonpi(ro):data$
So either enlarge the filesystem, or review what you’ve got stored, to investigate try:
pi@emonpi(ro):~$ cd /home/pi/data
pi@emonpi(ro):data$ sudo du -sm * | sort -rn
139     phpfina
30      mysql
23      emoncms-backup-2017-11-18.tar.gz
17      emoncms-backup-2017-09-26.tar.gz
7       node-red
1       wpa_supplicant.conf
The list above shows the total MB used for everything within /home/pi/data, where this is a directory, it is a summary of total used of ALL levels within that directory.
You could then traverse through the higher usage directories. I have 18 feeds, earliest dating back to March 2017, which uses 139MB.
As your filesystem is 194MB total, then I’d increase the filesystem size.
Clive.
Thanks Clive.
After a few reboots and a bit of trouble, I successfully started using a symbolic link to map the ~/data/phpfina directory to a directory on a usb-mounted SSD. I first copied over all the files in the phpfina directory. I don’t know if it’s ever a concern, but because the phpfina partition had been full, I was not concerned about copying files that were changing.
If I had not had a spare drive and had wanted to prune back the data in the phpfina directory, is there a recipe for nicely pruning?
I think my trailing question there was lost:
Is there any standard operating procedure for pruning back the phpfina directory as it becomes too big? 'anything automated?
Not that I have seen. The suggestion has come up a few times.
I saw your phpfina data (in the /home/pi/data directory) above:
You really don’t have much space available or much data. You might be better off buying a larger SD card and expanding the space so you have more room for data.
EDIT: See GitHub - emoncms/usefulscripts: Some useful scripts for administering Emoncms accounts
see sdpart directory (GitHub - emoncms/usefulscripts: Some useful scripts for administering Emoncms accounts)
