Hello Community.
I’m again noticing that the emoncms graphs are not updating. Upon first blush, the problem looked to be the same as Home emoncms graphs not updating, but it doesn’t look like a disk space issue this time. The feeds page seems to show updated feeds, but the phpfina directory stopped updating at “Jan 31 21:31” (or a few minutes before, depending on the file):
-rw-r--r-- 1 www-data www-data 6465152 Jan 31 21:09 19.dat
-rw-r--r-- 1 www-data www-data 6465144 Jan 31 21:09 20.dat
-rw-r--r-- 1 www-data www-data 6465144 Jan 31 21:09 21.dat
-rw-r--r-- 1 www-data www-data 6465132 Jan 31 21:09 23.dat
-rw-r--r-- 1 www-data www-data 6463988 Jan 31 21:09 30.dat
-rw-r--r-- 1 www-data www-data 6463980 Jan 31 21:09 31.dat
-rw-r--r-- 1 www-data www-data 6463424 Jan 31 21:09 32.dat
-rw-r--r-- 1 www-data www-data 6425816 Jan 31 21:09 38.dat
-rw-r--r-- 1 www-data www-data 1411632 Jan 31 21:09 63.dat
-rw-r--r-- 1 www-data www-data 1411644 Jan 31 21:09 62.dat
-rw-r--r-- 1 www-data www-data 1411400 Jan 31 21:09 67.dat
-rw-r--r-- 1 www-data www-data 1411448 Jan 31 21:09 66.dat
-rw-r--r-- 1 www-data www-data 1411460 Jan 31 21:09 65.dat
-rw-r--r-- 1 www-data www-data 1411368 Jan 31 21:09 70.dat
-rw-r--r-- 1 www-data www-data 1411380 Jan 31 21:09 69.dat
-rw-r--r-- 1 www-data www-data 1411392 Jan 31 21:09 68.dat
-rw-r--r-- 1 www-data www-data 6463028 Jan 31 21:10 33.dat
-rw-r--r-- 1 www-data www-data 6426104 Jan 31 21:10 37.dat
-rw-r--r-- 1 www-data www-data 6429308 Jan 31 21:10 36.dat
-rw-r--r-- 1 www-data www-data 6463028 Jan 31 21:10 34.dat
-rw-r--r-- 1 www-data www-data 6425548 Jan 31 21:10 41.dat
-rw-r--r-- 1 www-data www-data 6425684 Jan 31 21:10 40.dat
-rw-r--r-- 1 www-data www-data 6425772 Jan 31 21:10 39.dat
-rw-r--r-- 1 www-data www-data 470580 Jan 31 21:10 60.dat
-rw-r--r-- 1 www-data www-data 8703696 Jan 31 21:10 49.dat
-rw-r--r-- 1 www-data www-data 8778956 Jan 31 21:10 48.dat
-rw-r--r-- 1 www-data www-data 6425548 Jan 31 21:10 42.dat
-rw-r--r-- 1 www-data www-data 1411496 Jan 31 21:10 64.dat
-rw-r--r-- 1 www-data www-data 926488 Jan 31 21:10 73.dat
-rw-r--r-- 1 www-data www-data 6465224 Jan 31 21:11 14.dat
-rw-r--r-- 1 www-data www-data 6465228 Jan 31 21:12 15.dat
-rw-r--r-- 1 www-data www-data 6465184 Jan 31 21:12 16.dat
-rw-r--r-- 1 www-data www-data 6465184 Jan 31 21:12 17.dat
-rw-r--r-- 1 www-data www-data 6465180 Jan 31 21:31 18.dat
The SSD/disk is not full:
pi@emonpi(ro):log$ df -m ~/data/phpfina/
Filesystem 1M-blocks Used Available Use% Mounted on
/dev/sda1 112547 517 106291 1% /mnt/usb/sda1
pi@emonpi(ro):log$
I have no reason to believe it ever was close to being full. And I’ve confirm that that directory is still writable.
/var/log/emonhub/emonhub.log is still updating. I do see every few seconds a Discarding RX frame ‘unrelaiable content’? message though:
2018-02-01 19:02:47,925 DEBUG MQTT Publishing: emon/TX08Main/temp3 300
2018-02-01 19:02:47,925 DEBUG MQTT Publishing: emon/TX08Main/temp4 300
2018-02-01 19:02:47,925 DEBUG MQTT Publishing: emon/TX08Main/temp5 300
2018-02-01 19:02:47,926 DEBUG MQTT Publishing: emon/TX08Main/temp6 300
2018-02-01 19:02:47,926 DEBUG MQTT Publishing: emon/TX08Main/pulse 1
2018-02-01 19:02:47,926 INFO MQTT Publishing: emon/TX08Main/rssi -40
2018-02-01 19:02:47,927 INFO MQTT Publishing: emonhub/rx/8/values 452,441,28,13,120.47,300,300,300,300,300,300,1
2018-02-01 19:02:47,927 INFO MQTT Publishing: emonhub/rx/8/rssi -40
2018-02-01 19:02:48,295 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 10 49 207 124 96 16 245 177 20 26 36 64 160 230 102 221 107 247 253 242 201 (-93)
2018-02-01 19:02:49,903 DEBUG RFM2Pi 1198814 NEW FRAME : OK 19 93 0 0 0 127 1 25 0 (-62)
2018-02-01 19:02:49,905 DEBUG RFM2Pi 1198814 Timestamp : 1517511769.9
2018-02-01 19:02:49,905 DEBUG RFM2Pi 1198814 From Node : 19
2018-02-01 19:02:49,906 DEBUG RFM2Pi 1198814 Values : [9.3, 0, 38.300000000000004, 2.5]
2018-02-01 19:02:49,907 DEBUG RFM2Pi 1198814 RSSI : -62
2018-02-01 19:02:49,907 DEBUG RFM2Pi 1198814 Sent to channel(start)' : ToEmonCMS
2018-02-01 19:02:49,908 DEBUG RFM2Pi 1198814 Sent to channel(end)' : ToEmonCMS
2018-02-01 19:02:50,015 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 13 249 10 182 94 144 223 70 212 105 111 243 252 229 219 244 56 162 127 66 114 (-90)
2018-02-01 19:02:50,146 DEBUG RFM2Pi 1198815 NEW FRAME : OK 9 0 0 3 0 8 0 0 0 172 47 184 11 184 11 184 11 184 11 184 11 184 11 1 0 0 0 (-39)
2018-02-01 19:02:50,149 DEBUG RFM2Pi 1198815 Timestamp : 1517511770.15
2018-02-01 19:02:50,150 DEBUG MQTT Publishing: emon/TH19_Laundry/temperature 9.3
2018-02-01 19:02:50,150 DEBUG RFM2Pi 1198815 From Node : 9
2018-02-01 19:02:50,152 DEBUG RFM2Pi 1198815 Values : [0, 3, 8, 0, 122.04, 300, 300, 300, 300, 300, 300, 1, 0]
2018-02-01 19:02:50,153 DEBUG MQTT Publishing: emon/TH19_Laundry/external temperature 0
2018-02-01 19:02:50,153 DEBUG RFM2Pi 1198815 RSSI : -39
2018-02-01 19:02:50,155 DEBUG MQTT Publishing: emon/TH19_Laundry/humidity 38.3
2018-02-01 19:02:50,155 DEBUG RFM2Pi 1198815 Sent to channel(start)' : ToEmonCMS
2018-02-01 19:02:50,157 DEBUG RFM2Pi 1198815 Sent to channel(end)' : ToEmonCMS
2018-02-01 19:02:50,158 DEBUG MQTT Publishing: emon/TH19_Laundry/battery 2.5
2018-02-01 19:02:50,159 INFO MQTT Publishing: emon/TH19_Laundry/rssi -62
2018-02-01 19:02:50,161 INFO MQTT Publishing: emonhub/rx/19/values 9.3,0,38.3,2.5
2018-02-01 19:02:50,162 INFO MQTT Publishing: emonhub/rx/19/rssi -62
2018-02-01 19:02:50,264 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 17 244 20 72 223 22 212 134 29 180 153 176 56 56 97 218 33 241 219 215 123 (-86)
2018-02-01 19:02:50,369 DEBUG MQTT Publishing: emon/TX09SubP/D03_dryer 0
2018-02-01 19:02:50,371 DEBUG MQTT Publishing: emon/TX09SubP/D04_dryer 3
I don’t know if that is really a problem though. The history of that log does not go back to before the graph phpfina directory stopped updating.
Looking at /var/log/ I see that certain files and directories were updating until just before the problem:
-rw-r----- 1 root adm 940 Jan 25 01:36 ufw.log
-rw-r----- 1 root adm 1063571 Jan 29 02:17 auth.log.2
-rw-r----- 1 root adm 1063455 Jan 31 10:17 auth.log.1
-rw-r----- 1 root adm 1085594 Jan 31 15:17 daemon.log.2
-rw-r----- 1 root adm 1086584 Jan 31 18:17 syslog.2
drwxr-xr-x 2 openhab openhab 100 Jan 31 21:37 openhab
-rw-rw-rw- 1 root root 3210 Jan 31 21:38 emoncms.log
-rw-r----- 1 root adm 1086143 Feb 1 15:17 syslog.1
-rw-r----- 1 root adm 1069402 Feb 1 17:17 daemon.log.1
drwxr-xr-x 2 pi pi 80 Feb 1 18:17 logrotate
-rw-rw-r-- 1 root utmp 2688 Feb 1 18:36 wtmp
drwxr-xr-x 2 emonhub root 100 Feb 1 18:57 emonhub
-rw-r----- 1 root adm 793669 Feb 1 19:15 messages
-rw-r----- 1 root adm 798276 Feb 1 19:15 kern.log
-rw-rw-rw- 1 root root 487084 Feb 1 19:16 service-runner.log
-rw-r----- 1 root adm 521015 Feb 1 19:16 auth.log
-rw-r----- 1 root adm 183531 Feb 1 19:16 syslog
-rw-r----- 1 root adm 68300 Feb 1 19:16 daemon.log
As you can see, emoncms.log was one of those. It ends with…
2018-01-31 21:11:17.025|WARN|phpmqtt_input.php|Disconnected cleanly
2018-01-31 21:11:23.603|WARN|phpmqtt_input.php|Subscribing to: emon/#
2018-01-31 21:11:27.270|WARN|phpmqtt_input.php|Not connected, retrying connection
2018-01-31 21:11:30.863|WARN|phpmqtt_input.php|Connecting to MQTT server: Connection Accepted.: code: 0
2018-01-31 21:11:33.888|WARN|phpmqtt_input.php|Subscribed to topic: emon/#
2018-01-31 21:11:41.036|WARN|phpmqtt_input.php|Disconnected cleanly
2018-01-31 21:11:51.989|WARN|phpmqtt_input.php|Subscribing to: emon/#
2018-01-31 21:11:57.194|WARN|phpmqtt_input.php|Not connected, retrying connection
2018-01-31 21:12:02.529|WARN|phpmqtt_input.php|Connecting to MQTT server: Connection Accepted.: code: 0
2018-01-31 21:12:07.588|WARN|phpmqtt_input.php|Subscribed to topic: emon/#
2018-01-31 21:12:14.906|WARN|phpmqtt_input.php|Disconnected cleanly
2018-01-31 21:12:26.231|WARN|phpmqtt_input.php|Subscribing to: emon/#
2018-01-31 21:12:31.680|WARN|phpmqtt_input.php|Not connected, retrying connection
2018-01-31 21:12:32.142|WARN|phpmqtt_input.php|Connecting to MQTT server: Connection Accepted.: code: 0
2018-01-31 21:12:32.142|WARN|phpmqtt_input.php|Subscribed to topic: emon/#
2018-01-31 21:38:09.134|WARN|phpmqtt_input.php|Starting MQTT Input script
2018-01-31 21:38:10.571|WARN|phpmqtt_input.php|Subscribing to: emon/#
2018-01-31 21:38:10.571|WARN|phpmqtt_input.php|Not connected, retrying connection
2018-01-31 21:38:10.572|WARN|phpmqtt_input.php|Connecting to MQTT server: Connection Accepted.: code: 0
2018-01-31 21:38:10.572|WARN|phpmqtt_input.php|Subscribed to topic: emon/#emoncms
That “not connected” looks a bit odd to me, but it seemed to be there before the problem.
As you can also see above, the /var/log/openhab/ directory was also modified just before the problem. The content of that is:
-rw-r--r-- 1 openhab openhab 0 Jan 19 19:02 events.log
-rw-r--r-- 1 openhab openhab 1127 Jan 31 21:37 openhab-2018-03.log.zip
-rw-r--r-- 1 openhab openhab 1346 Jan 31 21:37 openhab.log
So it does look like the zipping up of the old log file happened just as the problem occurred.
Looking at what the new openhab.log file shows also suggests a problem:
2018-01-31 21:37:09.885 [ERROR] [.c.mqttv3.internal.ClientState] - openhab.1516388564568: Timed out as no activity, keepAlive=60,000 lastOutboundActivity=1,517,434,136,899 lastInboundActivity=1,517,433,161,121
2018-01-31 21:37:10.381 [ERROR] [o.i.t.m.i.MqttBrokerConnection] - MQTT connection to broker was lost
org.eclipse.paho.client.mqttv3.MqttException: Connection lost
at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:138) [mqtt-client-0.4.0.jar:na]
at java.lang.Thread.run(Thread.java:748) [na:1.8.0_151]
Caused by: java.io.EOFException: null
at java.io.DataInputStream.readByte(DataInputStream.java:267) ~[na:1.8.0_151]
at org.eclipse.paho.client.mqttv3.internal.wire.MqttInputStream.readMqttWireMessage(MqttInputStream.java:56) ~[na:na]
at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:100) [mqtt-client-0.4.0.jar:na]
... 1 common frames omitted
2018-01-31 21:37:10.383 [ERROR] [o.i.t.m.i.MqttBrokerConnection] - MQTT connection to 'mosquitto' was lost: Connection lost : ReasonCode 32109 : Cause : null
2018-01-31 21:37:10.384 [INFO ] [o.i.t.m.i.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker 'mosquitto'
2018-01-31 21:37:20.387 [INFO ] [o.i.t.m.i.MqttBrokerConnection] - Starting MQTT broker connection 'mosquitto'
Might the problem be the log zipping itself is incompatible with something using that log file?
Anyway, I’m posting in part for my benefit, and in part to help us all diagnose and fix/stabilize this. I assume that if I reboot, my phpfina directory will start populating again. Is there any information the community needs before I reboot?
Jason.
