Yes, you do it through the emonCMS on your emonPi.
Go to Setup > EmonHub > Edit Config
and find your emonPi - itâs Node 5:
[[5]]
nodename = emonpi
[[[rx]]]
units = W,W,W,V,C,C,C,C,C,C,p
All the values in names, datacodes etc are in order left - right, so to adjust Vrms you need to adjust the 4th value in scales = .
So to increase the reading in emoncms by 10%, youâd change it from 0.01 to 0.011
(Itâs 0.01 because your 240.12 V is sent as an integer: 24012, and to get back to volts, you multiply by 0.01)
That will not adjust the power value because the multiplication by current is done before this stage. Therefore youâll need to change the 3 powers by the same proportion - and thatâs assuming the current readings are spot on. If theyâre not, you need an additional adjustment for that too, but that adjustment will probably be different for power1 & power2. âpower1pluspower2â is the sum of the two, so thatâll need an average adjustment.
