I’ve got MyHeatPump publishing data to heatpumpmonitor, but my system is showing Heat Output and SCOP of 0 at the top of this page:
https://heatpumpmonitor.org/system/view?id=120
I think the rest of the data looks good.
Any ideas?
Thanks!
Any ideas?
Thanks!
Hmm… looks like a bug in the backend that’s tripped because the heat_kwh feed starts with null.
Try increasing the Start date to 1703688500. (i.e. from 14:37 to 14:48)
I’ve made the change to Start date, but the Heat Output is still showing 0. Does it recalculate on a schedule?
I’ve given it a nudge, and you’ll now see the correct values showing.
Thank you!
