Graphs not showing in public dash board
Hi guys , Paul here,
I have been going trough just about all the post that I could find and I suspect it is a IO issue so please forgive me if I duplicate,
I have setup a Graph and it works perfectly in data view but once I load it to the dash board it is not “zoom able” and you only see a place holder in public view. or a log in screen where the graph should be. All my feeds is public and all my current data is showing on the dash board.
Here is the link.
https://emoncms.org/paulf/WebPage
Is there a setting that I am missing?
Best regards
Paul
Ah got it sorted.
I had to create a Multi Graph under Visualisations and then load that into the dash and not load a graph from the data view page
The new graph module developments are currently “under construction” and @TrystanLea is tackling the “public” issue in the “Bugs in new graph module”.
For the moment Multigraphs are probably your best solution
