I have just updated my emonPI to the latest image (SD card purchased from shop) the import process went OK, sensors on the emonPI itself CT1,CT2 etc are working OK, but
external sensors I I have calling the PI are not updating.
I have a number of sensors round the house that make http calls to the emonPI e.g the immersion diverter:
http://192.168.1.57/input/post?node=elec_loads&fulljson={“divert”:494.7414749999999}&apikey=70619f2a2b25cb7d32**************
(api key have been obsfuriated)
These are getting a response of {“success”: true} - but the feeds are not updating in emon
I can even call the URL with API key in it from a browser and see the {“success”: true} but the feed does not update in the emon web screen
This affects all the feeds that log to the emonPI via API. Kassa plugs, weather station and a raspberyPI in the garage with some temperature sensors on the boiler
Am I missing something? or is there a log file where I can see what’s going wrong. The SD card is back on my desk, but I can mount it under linux using a card reader in my laptop to see the filesystem
I have replaced the original SD card and everything works fine again - feeds update.
vvvv emonPI info below vvvvv
—Server Information
Services
emonhub : Active Running
emoncms_mqtt : Active Running
feedwriter : Active Running - sleep 300s 380 feed points pending write
service-runner : Active Running
emonPiLCD : Active Running
redis-server : Active Running
mosquitto : Active Running
demandshaper : Not found or not installed
Emoncms
Version : low-write 11.3.20
Git :
URL : GitHub - emoncms/emoncms: Web-app for processing, logging and visualising energy, temperature and other environmental data
Branch : * stable
Describe : 11.3.20
Components : Emoncms Core v11.3.20 | App v2.7.2 | EmonHub Config v2.1.5 | Dashboard v2.3.3 | Device v2.2.2 | Graph v2.2.3 | Network Setup v1.0.2 | WiFi v2.1.1 | Backup v2.3.2 | Postprocess v2.2.7 | Sync v2.1.4 | Usefulscripts v2.3.10 | EmonScripts v1.6.18 | RFM2Pi v1.4.1 | Avrdude-rpi v1.0.1 | Emonhub v2.5.7 | EmonPi v2.9.5
Server
CPU : 1 Threads(s) | 4 Core(s) | 1 Sockets(s) | Cortex-A53 | 89.60MIPS |
OS : Linux 5.15.76-v7+
Host : emonpi | emonpi | (192.168.1.57)
Date : 2023-05-28 11:46:47 BST
Uptime : 11:46:48 up 33 min, 0 users, load average: 0.39, 0.30, 0.28
Memory
RAM : Used: 22.80%
Total : 922.14 MB
Used : 210.25 MB
Free : 711.88 MB
Swap : Used: 0.00%
Total : 100 MB
Used : 0 B
Free : 100 MB
Disk
: - / : Used: 40.84%
Total : 5.78 GB
Used : 2.36 GB
Free : 3.11 GB
Read Load : n/a
Write Load : n/a
Load Time : n/a
/boot : Used: 19.52%
Total : 254.99 MB
Used : 49.78 MB
Free : 205.21 MB
Read Load : n/a
Write Load : n/a
Load Time : n/a
/var/opt/emoncms : Used: 2.43%
Total : 9.61 GB
Used : 239.16 MB
Free : 8.88 GB
Read Load : n/a
Write Load : n/a
Load Time : n/a
/var/log : Used: 3.73%
Total : 50 MB
Used : 1.87 MB
Free : 48.13 MB
Read Load : n/a
Write Load : n/a
Load Time : n/a
HTTP
Server : Apache/2.4.54 (Raspbian) HTTP/1.1 CGI/1.1 80
MySQL
Version : 10.5.15-MariaDB-0+deb11u1
Host : 127.0.0.1 (127.0.0.1)
Date : 2023-05-28 11:46:47 (UTC 01:00)
Stats : Uptime: 2088 Threads: 7 Questions: 6396 Slow queries: 0 Opens: 47 Open tables: 40 Queries per second avg: 3.063
Redis
Version :
Redis Server : 6.0.16
PHP Redis : 6.0.0-dev
Host : localhost:6379
Size : 387 keys (775.23K)
Uptime : 0 days
MQTT Server
Version : Mosquitto 2.0.11
Host : localhost:1883 (127.0.0.1)
PHP
Version : 8.1.12 (Zend Version 4.1.12)
Run user : User: www-data Group: www-data video Script Owner: pi
Modules : apache2handler calendar Core ctype curl date dom v20031129exif FFI fileinfo filter ftp gd gettext hash iconv json libxml mbstring mosquitto v0.4.0mysqli mysqlnd vmysqlnd 8.1.12openssl pcre PDO pdo_mysql Phar posix readline redis v6.0.0-devReflection session shmop SimpleXML sockets sodium SPL standard sysvmsg sysvsem sysvshm tokenizer xml xmlreader xmlwriter xsl Zend OPcache zlib
Pi
Model : Raspberry Pi 3 Model B+ Rev 1.3 - 1GB (Sony UK)
Serial num. : 1D81EC23
CPU Temperature : 46.16°C
GPU Temperature : N/A (to show GPU temp execute this command from the console “sudo usermod -G video www-data” )
emonpiRelease : emonSD-10Nov22
File-system : read-write
Client Information
HTTP
Browser : Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/110.0
Language : en-GB,en;q=0.5
Window
Size : 1280 x 881
Screen
Resolution : 1280 x 1024
