Ah yes. Solution is as per documentation :frowning:
sudo emonSDexpand
pi@emonpi:~ $ df -h
Filesystem      Size  Used Avail Use% Mounted on
/dev/root       3.9G  1.6G  2.2G  42% /
devtmpfs        484M     0  484M   0% /dev
tmpfs           489M     0  489M   0% /dev/shm
tmpfs           489M   13M  476M   3% /run
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           489M     0  489M   0% /sys/fs/cgroup
tmpfs            50M  128K   50M   1% /var/log
tmpfs           1.0M     0  1.0M   0% /var/tmp
tmpfs            30M     0   30M   0% /tmp
/dev/mmcblk0p1   43M   22M   21M  52% /boot
/dev/mmcblk0p3   11G  113M  9.7G   2% /home/pi/data
tmpfs            98M     0   98M   0% /run/user/1000
warning, you can login by SSH while it is happening but the p3 is apparently missing. As the Pi does not actually shutdown and the LCD does not change, it is difficult to know if it has finished. Not being able to SSH indicated to me it was done.
