can anybody confirm that the settings in arduino IDE are correct…
and could sombody please guide me to wipe eeprom…
I am on a sharp deadline… I need to get the Heatpump module working… due to the fact that I have a big amount of funds that must be spent before the 1st of June… and it would be a shame to spend money on modules that do not work in this plant…
I like the specs on this module due to the fact it has a Mbus module that works in conjunction with a Kamstrup energi meter… and I need to log 3 heatpumps, 3 solar panels… some other water based energy storange…
read the entire guide, there are mentioned some libraries at the end of the the guide that you need to install in arduino IDE.
> If compiling fails because PubSubClient.h library cannot be found. Open the Library Manager again (Sketch > Include Library > Library Manager) and search for ‘PubSubClient’, install.
Many thanks for that it was the re-setting process that I really needed.
So when going though your really helpful process, I faced two challenges:
The latest EmonESP web_server.h has 2 includes:
#include <Hash.h>
#include <ESPAsyncTCP.h>
and they seemed to be missing, so I went back to an earlier version, which complied and uploaded OK (after re-installing PubSubClient )
After rebooting the Heatpumpmonitor card, the data sketch uploaded fine, however this is the second challenge and is the reason for wanting to re-flash it in the first place.
After removing the jumper from GP10 and rebooting, the ESP8266 is stuck in a boot loop, when I monitor the serial port I get
