ESP continually resetting. Any ideas?
Hi
Recently had a problem where I lost inputs from 2 of my emonESP devices. I misinterpreted the fault and decided to update the firmware on the ESP which in my case are wemos devices. Despite erasing flash first and then uploading firmware and spiffs using platformIO I keep seeing the following:
EmonESP 12880953
Firmware: 2.3.0
Starting APScan: 12 networks found
AP IP Address: 192.168.4.1
Server started
Commencing factory reset.
þactory reset complete! Resetting…
ets Jan 8 2013,rst cause:2, boot mode:(3,6)
load 0x4010f000, len 1384, room 16
tail 8
chksum 0x2d
csum 0x2d
v8b899c12
~ld
EmonESP 12880953
Firmware: 2.3.0
Starting APScan: 13 networks found
Server started
Assuming I had a duff ESP I used a new one but still get the same result. Out of interest I tried to upload Tasmota on the same ESP and that works perfectly.
This is driving me nuts! Any ideas?
That’s probably the GPIO0 (boot) being held low after flash.
Try allowing GPIO0 to go high after flashing.
It’s useful if you forget the wifi or admin settings, to put GPIO0 low to factory reset the device, but does mean it causes this apparent bootloop you’ve found!
Not sure that is an issue on a wemos. Also that doesn’t explain why Tasmota loads and runs without any problems. I only have the problem with emonESP firmware. I have a number of other wemos running emonESP and have never had this problem before.
Ian
Not sure, especially if you’re using Pio… should be pretty solid.
Master branch of emonESP from GitHub right?
The plot thickens.
Having success with Tasmota I thought I would try the EmonESP sonoff firmware.
I used the precompiled version here.
That works perfectly and I have not had a reset for about 10 minutes so far.
excellent.
The ‘timer’ branch of emonESP is designed to work with the smart plugs.
Unfortunately I need the branch that works with EmonTx.
I think I found the problem… 2 tics…
Try these.
Archive.zip (360.4 KB)
Thanks Dan
First I tried compiling with your platform ini. Compile still fails with:-
xtensa-lx106-elf-g++: internal compiler error: Aborted (program as)
Please submit a full bug report,
Then I used your firmware & spiffs uploaded with this command
esptool.py write_flash 0x000000 firmware.bin 0x7B000 spiffs.bin
Sadly the ESP starts ok but then resets.
EmonESP 12884640
Firmware: 2.3.1
Starting APScan: 10 networks found
Server started
ÿactory reset complete! Resetting...
tail 8
chksum 0x2d
csum 0x2d
vbb28d4a3
~ld
I then re-flashed the ESP with timer branch precompiled firmware and spiffs and that works perfectly.
I can only conclude something is still not quite right with EmonTx branch of the ESP software.
what exactly are you connecting to the Tx?
what firmware is the Tx running?
The ESP-MOD modules sold in the shop have a 4MB flash size, meaning the command to flash them would be:
esptool.py write_flash 0x000000 firmware.bin 0x300000 spiffs.bin
Hi Dan
I am connecting Wemos DI mini ESP modules. I have used these without problems in the past and have 3 running perfectly.
I have used both 4MB and 16MB modules.
The firmware on the Tx is fine.
To double check everything I went back to basics this morning. I deleted the EmonESP directory and cloned emonESP from github again.
It compiled and uploaded without any problems.
Still the same result, starts AP scan and then resets.
Out of interest I also did the same and tried with checking out timer branch.
This will definitely no longer compile. Could somebody confirm this or should I just raise this as an issue on Github?
Hi Ian,
Downloading the master branch from github just won’t work with PIO because the .ini is old, and will download the most recent ESP framework. Any framework above v2.5.0 won’t work with emonESP as it now stands.
I’ve only ever successfully compiled emonESP master with ArduinoIDE.
emonESP timer compiles fine with PIO, but not Arduino.
Maybe try compile emonESP master with ArduinoIDE.
Otherwise yes, raise a github issue and someone will have a look at updating the .ini to compile in PIO successfully again.
Hi Dan
That’s curious.
I can compile emonESP master with PIO but I get the reset problem.
I cannot compile emonESP timer with PIO it faults out.
Raised github issue.
I will try ArduinoIDE again.
Hi Dan
Which ESP framework version are you using in arduino IDE?
Ian
v2.4.2
There’re are a few libraries to download for ArduinoIDE.
PubSubClient
Async…
Hi Dan
Some progress. I have managed to compile using Arduino.
Now the ESP starts APScan and does not reset. This kind of confirms there are issues with the platformIO compiling.
Sadly I now see the device on my smart phone but all I get when I try to connect is:-
Obtaining IP address…
Then after a considerable time it gives up showing on the phone:-
IP Configuration Failure
I did erase the ESP before uploading the new firmware and SPIFFS.
Now totally stuck!
That’s a similar problem I had with the 2.5.2 framework of esp8266 for arduino.
You’ve definitely selected the correct version, version 2.4.2, in the boards manager?
Thanks Dan
That was it. I am sure I had selected 2.4.2 framework but it was on 2.5.2.
Corrected that and the problem with resetting is fixed. I can now access EmonESP and everything should be fine. Sadly its not. I cannot get it to connect to my server. I have no idea why. I have other EmonESP units running and I have copied the server settings from them and pasted the write key from my server.
Is there any way to debug the running EmonESP. I have it connected with a serial port but all it shows is:
EmonESP 2056056
Firmware: BUILD_TAG
Connecting to SSID: studiooutside
Connected, IP: 192.168.1.53
Server started
Webpage connection shows:-
There’s a debug.h header, a tab should be viewable in Arduino.
debug.h seems designed for use with PIO. I’ve never used it. A quick look may suggest uncommenting this might help:
//#define DEBUG
Hi Dan
Many thanks. I am now working!
I changed debug and went through the complete firmware upload again and now it is working. However it may have been OK all the time. I filled in all the parameters and hit Save.
Response was:-
Connected: No
For some reason at that stage I hit the HTTP link below the latest data window
http://192.168.1.110/input?string=CT1:3935,CT2:325,T0:20.5
Immediately all the EmonESP windows cleared and response was Connected:Yes.
I looked at my emoncms inputs and there was the data.
I refreshed the EmonESP http connection and the Emoncms windows had information apart from apikey which always shows blank.
So I think the issue was my expectation of connected showing yes on save not realising the connection was not checked until data was sent.
