I just realized im getting error: PCF8574 is NOT fitted, relay control not possible!
I boards built by JLCPCB and the IC on the controller boards are PCF8574T
Ive found some posts that mention that if using a slightly different version the i2c address is different. But since these are built using the BOM file, shouldn’t the i2c address be correct?
Or should I change the i2c address in the main.cpp to 0x20 ???
Now after reflashing the 8266 d1 mini isn’t broadcasting a ssid…
When flashing with vscode platformio I’m getting the “time” error periodically… But even when It flashes with out the error it still doesn’t broadcast a ssid…
I went to GitHub link mentioned in main.cpp and tried the renaming time.h etc… But still nothing
