Hi All,
I’ve had my EmonTx4 up and running for a few days now with radio disabled and CT3 set to 20A.
However, I’ve noticed this sort of thing a couple of times:
When I’ve gone back to the Serial Config, the radio is back enabled and CT3 is back to 50A.
I can plug into CT4 for now but wanted to report the issue.
I’m struggling to find steps to reproduce but I have been messing with the EmonHub config. I can can say with certainty that I have not been anywhere near the Serial Config page at the times where this has happened.
Thanks,
Chris
borpin
(Brian Orpin)
2
In the box for issuing commands, you need to type an s to save to EEPROM.
This is a bit of a Beta function ATM so I’m sure a Save button will appear.
Hi @borpin,
It definitely saves everything because the readings have been fine.
But this has happened on a couple of occasions.
Chris
Not necessarily. If Trystan is using the ‘old’ emonTx V3 setup - it saves the settings to memory immediately, but to EEPROM only when you do a 's’ave. This is deliberate so that you have a fall-back in case you get into a mess - restarting without doing a 's’ave restores the last version saved to EEPROM.
@Robert.Wall I say definitely because I’ve seen the message about saving to EEPROM, closed the Serial Config, started up EmonHub and the readings have been fine for a while.
borpin
(Brian Orpin)
6
But did you reboot the EmonTX?
Can you try that and check the settings have been retained.
But are you sure you saved first? - Did you see the saved data echoed back? Closing the Serial Config in the browser doesn’t save.
If that’s not the problem, then are rogue characters being sent to the serial input - say during plugging/unplugging, or restarting whatever follows the programmer?
Here’s my documentation for the emonTx V3CM version. Your sketch might not use all (or any!) of this.
Config.pdf (47.9 KB)
borpin
(Brian Orpin)
8
Just tried it myself. When you change something a ‘save’ button appears.
This does then save to EEPROM - you see the data and then the saved message.
Odd it seems to be reverting then.
@borpin - Yeah. I’ve doubled checked that all works by editing, saving, then going back in and it loads the saved configuration.
MSG also went to 0 at the same time so it’s like it’s completely reset.
TrystanLea
(Trystan Lea)
11
Hello @abbbbbottttt On the serial config page, when the emonTx4 connects, could you check the firmware version that you have there? it should be printed in the log window.
TrystanLea
(Trystan Lea)
12
I think I’ve experienced this on one test system here, but Im struggling to reproduce it in a way that would allow me to understand what might be happening. If you notice this again @abbbbbottttt or anyone else please let me know.
@TrystanLea Will do. To be honest, I moved my 20A clip to one of the ones that defaults to 20A and P3 is now empty. However, I’ll notice if the radio re-enables. That said, it’s been stable since I stopped messing around with Serial Config, restarting Emonhub,etc.
TrystanLea
(Trystan Lea)
14
I was able to replicate this issue properly this morning and realise that it’s a fundamental issue affecting emonTx4 firmware versions up to and including v1.5.3.
I’ve now fixed this in v1.5.4 which is now available as a release here: Release 1.5.4 · openenergymonitor/emontx4 · GitHub
If compiling from source it is important to update your local copy of the emonEProm library in addition to the main emonTx4 firmware directory (GitHub - openenergymonitor/emonEProm at avrdb)
The easiest way to upload the latest firmware is via a USB-C cable connected to an emonPi or emonBase. See: https://docs.openenergymonitor.org/emontx4/firmware.html#updating-firmware-using-an-emonbase
I will contact those who have already received emonTx4 units to notify about this and recommend a firmware update.
borpin
(Brian Orpin)
15
@TrystanLea - docs site needs updating (references 1.5.3 as latest).
You can use latest in the URL for a permanent ref to latest firmware which I think automatically updates the link text. https://github.com/openenergymonitor/emontx4/releases/latest Release 1.5.4 · openenergymonitor/emontx4 · GitHub
A reminder of which is which (Classic/Latest/LPL) would not go amiss I suspect in the docs as well (even a link to definition).
LPL is factory default, I think?
TrystanLea
(Trystan Lea)
16
Updated, thanks!
Id does say on there that the default is LowPowerLabs and that there are the other options. Do you think it’s not clear enough on that page?
@TrystanLea - The only bit that caught me out when updating from the emonBase is that do you need to do a system update before trying the firmware update? It seemed to be that way.
TrystanLea
(Trystan Lea)
18
A little more background on the issue fixed above:
The emonTx4 EEPROM is used for two different functions:
1. Storing configuration e.g radio, nodeid, CT channel calibrations etc.
2. Storing cumulative energy values
The emonTx4 EEPROM size is 512 bytes long.
The configuration section currently takes up bytes 0-105.
With the fix today (v1.5.4) the energy values are stored in a circular buffer 13x29bytes long = 377 bytes total, starting on byte 132 through to byte 508.
My mistake in the previous version was to mistake the block size to be 28 bytes, I then allocated 14 blocks starting at byte 110. (110+(28×14))=502 bytes which would have been ok. There is however an identification byte alongside each block of energy values, which makes each block 29 bytes long, (110+(29x14)) = 516 bytes, which unfortunately caused the last few bytes to wrap around and erase the expected signature at the start of the EEPROM resulting in the configuration resetting.
The fix today shortens the circulation buffer by one block and also moves that circular buffer a little further from the config section so that we can add more config options in future if needed.
TrystanLea
(Trystan Lea)
20
Yes good point, that is required
