Somebody has messed around with Github and moved it. It is now very well hidden - it took me ages to find it:
EmonLibCM will work with an emonTx V3.2, the problem is the radio - you need a patched version of JeeLib (RFu_JeeLib) or you can use my rfmTxLib (transmit only) which works equally well with the
emonTx V3.2 or V3.4. It’s available here:
So, if you would like the latest continuous monitoring, I suggest to take the V3.4 sketch and replace the file “rfm.ino” with rfmTxLib - you might need some small changes to the calls to library functions, but without checking in detail, I can’t say what, but they are quite similar (because I wrote both
Here’s a list of all the I/O pins used in various hardware, check for changes between the V3.4 and your V3.2 (e.g. you don’t have DIP switches - those need to be deleted) .
emonTx I/O
