Hello all,
am designing a customized emonTx using the Arduino Uno ATmega328 uController, I have built a prototype on a breadboard and will like the community to help me valid the data am getting as regards the realPower and apparentPower.
I get two different reading of the real and apparent power when a load is connect and when no load is connect, am not sure if it suppose to be so
Here is the serial print output with load: (Electric Iron rated 220-240v, 2000-2400w)
1392.37 1397.43 214.79 6.51 1.00
1381.77 1384.42 214.07 6.47 1.00
1390.55 1392.04 214.84 6.48 1.00
1392.25 1393.25 214.89 6.48 1.00
1391.87 1392.41 214.89 6.48 1.00
1389.64 1390.21 214.84 6.47 1.00
1393.16 1393.65 214.96 6.48 1.00
1392.06 1392.27 214.91 6.48 1.00
1381.37 1381.65 214.18 6.45 1.00
1390.65 1391.04 214.97 6.47 1.00
1394.57 1394.78 215.11 6.48 1.00
1391.34 1391.62 214.87 6.48 1.00
1380.94 1381.31 214.23 6.45 1.00
1395.58 1395.83 215.18 6.49 1.00
and here without load:
0.20 8.46 223.86 0.04 0.02
-0.34 5.97 223.33 0.03 -0.06
0.69 9.93 222.45 0.04 0.07
0.28 4.16 223.61 0.02 0.07
-0.07 5.15 222.73 0.02 -0.01
-0.27 3.72 223.43 0.02 -0.07
-0.18 7.22 222.49 0.03 -0.03
0.11 5.24 223.93 0.02 0.02
0.27 3.77 222.61 0.02 0.07
0.70 6.33 223.31 0.03 0.11
-0.01 0.98 222.84 0.00 -0.01
-0.20 5.20 222.82 0.02 -0.04
-0.56 7.28 223.43 0.03 -0.08
0.08 3.82 223.44 0.02 0.02
as can be seen the real and apparent power is same and a power factor of 1.0 with load connected
and not so without load.
am about to order the PCB but am a bit concern about the difference in readings
is this the expected behavior or am I missing something
