Robert, in another thread, you wrote:
Unfortunately, this is the expected behaviour because what you are seeing under no-load conditions is noise from the digital circuits in the processor getting into the analogue input. Then, when you calculate the rms current, the noise is rectified by the maths and appears as a (relatively) large apparent power, whereas when you multiply each sample of voltage and current to get real power, the noise, not being rectified, tends to get averaged out.
Ref:
As he’s calculating only apparent power,
is that essentially what he’s seeing?
