Hi - My eomon pi has gone mental. It’s lost a load of data locally, which although a shame is not the end of the world. However, it now updates from its inputs infrequently around 60-80 seconds, has self created a million and one “inactive” inputs - many have some data assigned to them and it would appear to have self created a lode of nodes as well. I can no longer get to the device using its statically assigned IP address, but can attach via the dynamically assigned address. It is still updating the online version, so I am not too worried about wiping it if required and would like to bring it up to the newer base install anyway, which I suspect means losing all the local data anyway.
Model Raspberry Pi 3 Model B Rev 1.2 - 1 GB (Stadium)
SoC Broadcom BCM2835
Serial num. 62C8F2E4
Temperature 50.46°C - 50.5°C
emonpiRelease emonSD-26Oct17
A couple of questions:
- can I repair it or would it be better to move forward with the base install anyway? Happy to try either
- If I move to the new install - or indeed wipe this and rebuild it - will I lose the data on line? I’m trying to build a view of my energy use over a year - to see the savings from solar panels etc so dont want to lose the online data - no so worried about the local data.
- Why does it keep self creating nodes and inputs etc?
LAST ENTRIES ON THE LOG FILE
Starting update via service-runner-update.sh (v2.0) >
Filesystem is unlocked - Write access
type ' rpi-ro ' to lock
- emonSD version: emonSD-26Oct17
emonSD base image check passed...continue update
git pull /home/pi/emonpi
* master
wifiap
On branch master
Your branch is up-to-date with 'origin/master'.
Untracked files:
(use "git add ..." to include in what will be committed)
1
nothing added to commit but untracked files present (use "git add" to track)
Already up-to-date.
Main Update Script
Date: Mon 17 Jun 21:15:12 UTC 2019
EUID: 1000
usrdir: /home/pi
type: all
firmware: emonpi
Checking environment:
- pi user found
EUID: 1000
Hardware detected: EmonPi
Stopping emonPiLCD service
Display update message on LCD
I2C LCD DETECTED Ox27
Hit http://ppa.launchpad.net xenial InRelease
Hit http://mirrordirector.raspbian.org jessie InRelease
Get:1 http://repo.mosquitto.org jessie InRelease [11.0 kB]
Ign http://dl.bintray.com stable InRelease
Hit http://archive.raspberrypi.org jessie InRelease
Get:2 http://dl.bintray.com stable Release.gpg [821 B]
Get:3 http://dl.bintray.com stable Release [6,051 B]
Err http://repo.mosquitto.org jessie InRelease
Hit http://ppa.launchpad.net xenial/main Sources
Hit http://ppa.launchpad.net xenial/main armhf Packages
Hit http://ppa.launchpad.net xenial/main Translation-en
Get:4 http://dl.bintray.com stable/main armhf Packages [77.8 kB]
Hit http://archive.raspberrypi.org jessie/main armhf Packages
Hit http://archive.raspberrypi.org jessie/ui armhf Packages
Hit http://mirrordirector.raspbian.org jessie/main armhf Packages
Hit http://mirrordirector.raspbian.org jessie/contrib armhf Packages
Hit http://mirrordirector.raspbian.org jessie/non-free armhf Packages
Hit http://mirrordirector.raspbian.org jessie/rpi armhf Packages
Ign http://archive.raspberrypi.org jessie/main Translation-en_GB
Ign http://archive.raspberrypi.org jessie/ui Translation-en_GB
Ign http://dl.bintray.com stable/main Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/main Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en_GB
Fetched 84.6 kB in 22s (3,689 B/s)
Reading package lists...
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://repo.mosquitto.org jessie InRelease: The following signatures were invalid: KEYEXPIRED 1515017477 KEYEXPIRED 1515017477 KEYEXPIRED 1515017477
W: Failed to fetch http://repo.mosquitto.org/debian/dists/jessie/InRelease
W: Some index files failed to download. They have been ignored, or old ones used instead.
Building dependency tree...
Reading state information...
rng-tools is already the newest version.
python-gpiozero is already the newest version.
python-rpi.gpio is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 139 not upgraded.
Requirement already up-to-date: paho-mqtt in /usr/local/lib/python2.7/dist-packages
You are using pip version 8.1.2, however version 19.1.1 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
git pull /home/pi/RFM2Pi
* master
On branch master
nothing to commit, working directory clean
Already up-to-date.
git pull /home/pi/usefulscripts
* master
On branch master
Already up-to-date.
git pull /home/pi/huawei-hilink-status
* master
On branch master
Already up-to-date.
git pull /home/pi/oem_openHab
* master
On branch master
Already up-to-date.
git pull /home/pi/oem_node-red
* master
On branch master
Already up-to-date.
EmonPi Firmware Update
Start ATmega328 serial upload using avrdude with latest.hex
Discrete Sampling
avrdude -c arduino -p ATMEGA328P -P /dev/ttyAMA0 -b 115200 -U flash:w:/home/pi/emonpi/firmware/compiled/latest.hex
avrdude-original: Using autoreset DTR on GPIO Pin 7
avrdude-original: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude-original: Device signature = 0x1e950f
avrdude-original: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude-original: erasing chip
avrdude-original: reading input file "/home/pi/emonpi/firmware/compiled/latest.hex"
avrdude-original: input file /home/pi/emonpi/firmware/compiled/latest.hex auto detected as Intel Hex
avrdude-original: writing flash (17886 bytes):
Writing | ################################################## | 100% 2.48s
avrdude-original: 17886 bytes of flash written
avrdude-original: verifying flash memory against /home/pi/emonpi/firmware/compiled/latest.hex:
avrdude-original: load data flash data from input file /home/pi/emonpi/firmware/compiled/latest.hex:
avrdude-original: input file /home/pi/emonpi/firmware/compiled/latest.hex contains 17886 bytes
avrdude-original: reading on-chip flash data:
Reading | ################################################## | 100% 1.88s
avrdude-original: verifying ...
avrdude-original: 17886 bytes of flash verified
strace: |autoreset: Broken pipe
avrdude-original done. Thank you.
Start emonhub update script:
emonHub update started
- usr directory: /home/pi
git pull /home/pi/emonhub
K0den-wibeee_interface
* emon-pi
hmm01i-syslogging
On branch emon-pi
Your branch is up-to-date with 'origin/emon-pi'.
Already up-to-date.
Creating emonhub logfile
Symlinking emonhub.conf to /etc/emonhub/emonhub.conf
emonhub.service already installed
Running emonhub automatic node addition script
[[5]]
Node 5 already present
[[6]]
Node 6 already present
[[7]]
Node 7 already present
[[8]]
Node 8 already present
[[9]]
Node 9 already present
[[10]]
Node 10 already present
[[11]]
Node 11 already present
[[12]]
Node 12 already present
[[13]]
Node 13 already present
[[14]]
Node 14 already present
[[19]]
Node 19 already present
[[20]]
Node 20 already present
[[21]]
Node 21 already present
[[22]]
Node 22 already present
[[23]]
Node 23 already present
[[24]]
Node 24 already present
[[25]]
Node 25 already present
[[26]]
Node 26 already present
Start emoncms update:
Emoncms update started
Emoncms update script V1.3 (26th March 2019)
- emoncms directory: /var/www/emoncms
current settings.php md5: 0e4803a641b7784ed23edf87506ce761
Default settings.php md5: 0e4803a641b7784ed23edf87506ce761
settings.php has NOT been user modifed
Checking status of /var/www/emoncms git repository
- git branch: stable
- no local changes
- running: git pull origin stable
From https://github.com/emoncms/emoncms
* branch stable -> FETCH_HEAD
Already up-to-date.
NEW default settings.php md5: 0e4803a641b7784ed23edf87506ce761
settings.php not updated
Updating Emoncms Modules
Updating /var/www/emoncms/Modules/app module
- git tags: 1.2.0-108-g6e5016a
- no local changes
From https://github.com/emoncms/app
Already up-to-date.
Updating /var/www/emoncms/Modules/config module
- git tags: 1.0.0-63-g1d9238e
- no local changes
From https://github.com/emoncms/config
Already up-to-date.
Updating /var/www/emoncms/Modules/dashboard module
- git tags: 1.3.1-115-gabd1a0b
- no local changes
From https://github.com/emoncms/dashboard
Already up-to-date.
Updating /var/www/emoncms/Modules/device module
- git branch: master
- git tags: 1.1.1-48-g2ea6e74
- no local changes
- running: git pull origin master
From https://github.com/emoncms/device
* branch master -> FETCH_HEAD
Already up-to-date.
Updating /var/www/emoncms/Modules/graph module
- git tags: 1.2.1-151-gc7f4ea9
- no local changes
From https://github.com/emoncms/graph
Already up-to-date.
Updating /var/www/emoncms/Modules/wifi module
- git tags: 1.2.0-39-gb67783d
- no local changes
From https://github.com/emoncms/wifi
Already up-to-date.
Updating postprocess module
- git branch: emonpi
- git tags: 2.1.0
- no local changes
- running: git pull origin emonpi
Already up-to-date.
Already on 'emonpi'
Your branch is up-to-date with 'remotes/origin/emonpi'.
Updating sync module
- git tags: 2.0.1-2-gc5eb931
- no local changes
Already up-to-date.
Already on 'master'
Updating backup module
- git tags: 2.0.0-12-g67a1f1d
- no local changes
Already up-to-date.
Already on 'stable'
Your branch is up-to-date with 'origin/stable'.
Auto Installation of Emoncms Modules
- graph module already installed
- device module already installed
- postprocess module already installed
- sync module already installed
- backup module already installed
www-data : www-data video systemd-journal
SERVICES
emoncms_mqtt.service already installed
feedwriter.service already installed
service-runner.service already installed
Reloading systemctl deamon
Update Emoncms database
Restarting Services...
- sudo systemctl restart feedwriter.service
--- ActiveState=active ---
- sudo systemctl restart emoncms_mqtt.service
- sudo systemctl restart emonhub.service
- sudo /etc/init.d/openhab restart
Restarting openhab (via systemctl): openhab.service.
● openhab.service - Starts and stops the openHAB Home Automation Bus
Loaded: loaded (/usr/lib/systemd/system/openhab.service; enabled)
Active: active (running) since Mon 2019-06-17 21:16:33 UTC; 91ms ago
Docs: http://www.openhab.org
Process: 7219 ExecStartPre=/usr/share/openhab/bin/setpermissions.sh (code=exited, status=0/SUCCESS)
Main PID: 7265 (openhab.sh)
CGroup: /system.slice/openhab.service
├─7265 /bin/sh /usr/share/openhab/bin/openhab.sh -o
└─7287 /usr/bin/java -Dlogback.configurationFile=/etc/openhab/logback.xml -Dosgi.clean=true -Declipse.ignoreApp=true -Dosgi.noShutdown=true -Djetty.port=8080 -Dopenhab.configfile=/etc/openhab/configurations/openhab.cfg -Dopenhab.configdir=/etc/openhab/configurations -Dopenhab.logdir=/var/log/openhab -Dsmarthome.userdata=/var/lib/openhab -Djetty.home=/usr/share/openhab -Djetty.port.ssl=8443 -Djetty.config=/etc/openhab/jetty -Djetty.logs=/var/log/openhab -Djetty.rundir=/usr/share/openhab -Dfelix.fileinstall.dir=/usr/share/openhab/addons -Dfelix.fileinstall.filter=.*\.jar -Djava.library.path=/usr/share/openhab/lib -Djava.security.auth.login.config=/etc/openhab/login.conf -Dorg.quartz.properties=/etc/openhab/quartz.properties -Dequinox.ds.block_timeout=240000 -Dequinox.scr.waitTimeOnBlock=60000 -Dfelix.fileinstall.active.level=4 -Djava.awt.headless=true -jar /usr/share/openhab/server/plugins/org.eclipse.equinox.launcher_1.3.0.v20120522-1813.jar -configuration /var/lib/openhab/workspace -data /var/lib/openhab/workspace -console 5555
Jun 17 21:16:33 emonpi setpermissions.sh[7219]: setting owner openhab:openhab recursively for /var/lib/openhab
Jun 17 21:16:33 emonpi setpermissions.sh[7219]: setting permissions and owner openhab:openhab recursively for /var/log/openhab
Jun 17 21:16:33 emonpi setpermissions.sh[7219]: setting permissions and owner openhab:openhab recursively for /etc/openhab/configurations
Jun 17 21:16:33 emonpi setpermissions.sh[7219]: setting permissions and owner openhab:openhab for /usr/share/openhab/webapps/static
Jun 17 21:16:33 emonpi setpermissions.sh[7219]: setting permissions and owner openhab:openhab for /etc/openhab/jetty/etc/keystore
Jun 17 21:16:33 emonpi setpermissions.sh[7219]: setting permissions and owner openhab:openhab for /etc/openhab/configurations/users.cfg
Jun 17 21:16:33 emonpi systemd[1]: Started Starts and stops the openHAB Home Automation Bus.
Symlinking emonpiupdate.log
Installing emoncms logrotate...
Now setting up Logrotate...
Backing up old logrotate configuration...
Linked to new logrotate configuration...
Backing up old logrotate cron job...
mv: cannot stat ‘/etc/cron.daily/logrotate’: No such file or directory
Linked to new logrotate cron job...
Completed
Completed
Running logrotate...
set log rotate config owner to root
Emoncms update script complete
Starting emonPi LCD service..
Filesystem is locked - Read Only access
type ' rpi-rw ' to unlock
emonPi update done: Mon 17 Jun 21:16:43 UTC 2019
restarting service-runner
