2020-11-29 21:02:07,088 INFO MainThread Opening hub...
2020-11-29 21:02:07,095 INFO MainThread Logging level set to DEBUG
2020-11-29 21:02:07,103 INFO MainThread Creating EmonHubJeeInterfacer 'RFM2Pi'
2020-11-29 21:02:07,117 DEBUG MainThread Opening serial port: /dev/ttyAMA0 @ 38400 bits/s
2020-11-29 21:02:09,128 WARNING MainThread Device communication error - check settings
2020-11-29 21:02:09,139 INFO MainThread Setting RFM2Pi frequency: 433 (4b)
2020-11-29 21:02:10,150 INFO MainThread Setting RFM2Pi group: 210 (210g)
2020-11-29 21:02:11,162 INFO MainThread Setting RFM2Pi quiet: 0 (0q)
2020-11-29 21:02:12,175 INFO MainThread Setting RFM2Pi baseid: 5 (5i)
2020-11-29 21:02:13,209 INFO MainThread Setting RFM2Pi calibration: 230V (1p)
2020-11-29 21:02:14,221 DEBUG MainThread Setting RFM2Pi subchannels: ['ToRFM12']
2020-11-29 21:02:14,232 DEBUG MainThread Setting RFM2Pi pubchannels: ['ToEmonCMS']
2020-11-29 21:02:14,245 INFO MainThread Creating EmonHubMqttInterfacer 'MQTT'
2020-11-29 21:02:14,265 INFO MainThread MQTT Init mqtt_host=127.0.0.1 mqtt_port=1883 mqtt_user=emonpi
2020-11-29 21:02:14,268 DEBUG RFM2Pi 1 NEW FRAME : 11 11 0 7 0 28 0
2020-11-29 21:02:14,284 DEBUG RFM2Pi 1 Timestamp : 1606694534.27
2020-11-29 21:02:14,306 DEBUG RFM2Pi 1 From Node : 11
2020-11-29 21:02:14,312 INFO MainThread Creating EmonHubEmoncmsHTTPInterfacer 'emoncmsorg'
2020-11-29 21:02:14,323 DEBUG RFM2Pi 1 Values : [11, 7, 28]
2020-11-29 21:02:14,339 DEBUG RFM2Pi 1 Sent to channel(start)' : ToEmonCMS
2020-11-29 21:02:14,351 DEBUG RFM2Pi 1 Sent to channel(end)' : ToEmonCMS
2020-11-29 21:02:14,412 INFO MQTT Connecting to MQTT Server
2020-11-29 21:02:14,431 INFO MQTT connection status: Connection successful
2020-11-29 21:02:14,443 DEBUG MQTT CONACK => Return code: 0
2020-11-29 21:02:14,567 DEBUG MQTT Publishing: emon/11/1 11
2020-11-29 21:02:14,578 DEBUG MQTT Publishing: emon/11/2 7
2020-11-29 21:02:14,587 DEBUG MQTT Publishing: emon/11/3 28
2020-11-29 21:02:14,597 INFO MQTT Publishing: emon/11/rssi 0
2020-11-29 21:02:14,607 INFO MQTT Publishing: emonhub/rx/11/values 11,7,28
2020-11-29 21:02:14,616 INFO MQTT Publishing: emonhub/rx/11/rssi 0
2020-11-29 21:02:14,627 INFO MQTT on_subscribe
2020-11-29 21:02:16,695 DEBUG RFM2Pi 2 NEW FRAME : 11 9 0 3 0 27 0
2020-11-29 21:02:16,715 DEBUG RFM2Pi 2 Timestamp : 1606694536.69
2020-11-29 21:02:16,731 DEBUG RFM2Pi 2 From Node : 11
2020-11-29 21:02:16,739 DEBUG RFM2Pi 2 Values : [9, 3, 27]
2020-11-29 21:02:16,746 DEBUG RFM2Pi 2 Sent to channel(start)' : ToEmonCMS
2020-11-29 21:02:16,753 DEBUG RFM2Pi 2 Sent to channel(end)' : ToEmonCMS
2020-11-29 21:02:16,980 DEBUG MQTT Publishing: emon/RPICT3/P1 9
2020-11-29 21:02:16,991 DEBUG MQTT Publishing: emon/RPICT3/P2 3
2020-11-29 21:02:17,000 DEBUG MQTT Publishing: emon/RPICT3/P3 27
2020-11-29 21:02:17,010 INFO MQTT Publishing: emon/RPICT3/rssi 0
2020-11-29 21:02:17,019 INFO MQTT Publishing: emonhub/rx/11/values 9,3,27
2020-11-29 21:02:17,031 INFO MQTT Publishing: emonhub/rx/11/rssi 0
2020-11-29 21:02:21,601 DEBUG RFM2Pi 3 NEW FRAME : 11 7 0 5 0 30 0
2020-11-29 21:02:21,612 DEBUG RFM2Pi 3 Timestamp : 1606694541.6
2020-11-29 21:02:21,619 DEBUG RFM2Pi 3 From Node : 11
2020-11-29 21:02:21,627 DEBUG RFM2Pi 3 Values : [7, 5, 30]
2020-11-29 21:02:21,634 DEBUG RFM2Pi 3 Sent to channel(start)' : ToEmonCMS
2020-11-29 21:02:21,641 DEBUG RFM2Pi 3 Sent to channel(end)' : ToEmonCMS
2020-11-29 21:02:21,911 DEBUG MQTT Publishing: emon/RPICT3/P1 7
2020-11-29 21:02:21,923 DEBUG MQTT Publishing: emon/RPICT3/P2 5
2020-11-29 21:02:21,936 DEBUG MQTT Publishing: emon/RPICT3/P3 30
2020-11-29 21:02:21,950 INFO MQTT Publishing: emon/RPICT3/rssi 0
2020-11-29 21:02:21,965 INFO MQTT Publishing: emonhub/rx/11/values 7,5,30
2020-11-29 21:02:21,979 INFO MQTT Publishing: emonhub/rx/11/rssi 0
2020-11-29 21:02:26,390 DEBUG RFM2Pi 4 NEW FRAME : 11 5 0 4 0 28 0
2020-11-29 21:02:26,405 DEBUG RFM2Pi 4 Timestamp : 1606694546.39
2020-11-29 21:02:26,415 DEBUG RFM2Pi 4 From Node : 11
2020-11-29 21:02:26,426 DEBUG RFM2Pi 4 Values : [5, 4, 28]
2020-11-29 21:02:26,436 DEBUG RFM2Pi 4 Sent to channel(start)' : ToEmonCMS
2020-11-29 21:02:26,446 DEBUG RFM2Pi 4 Sent to channel(end)' : ToEmonCMS
2020-11-29 21:02:26,566 DEBUG MQTT Publishing: emon/RPICT3/P1 5
2020-11-29 21:02:26,576 DEBUG MQTT Publishing: emon/RPICT3/P2 4
2020-11-29 21:02:26,586 DEBUG MQTT Publishing: emon/RPICT3/P3 28
2020-11-29 21:02:26,596 INFO MQTT Publishing: emon/RPICT3/rssi 0
2020-11-29 21:02:26,614 INFO MQTT Publishing: emonhub/rx/11/values 5,4,28
2020-11-29 21:02:26,624 INFO MQTT Publishing: emonhub/rx/11/rss```
