OK I understand it now, re sitting and cleaning didn’t solved it.
Unfortunately, that part, I don’t know.
I’ve had a look at the shop, looks like the emonbase was ordered in September, 2016.
Thanks @emontxv3, could you try uploading the firmware to the RFM69Pi again from the Emoncms admin interface, select the RFM69Pi firmware and then click “Update Firmware”
YES, GREAT.
All is working again.
Even the backup is accepted and the history is restored.
Thank you very much to all.
Great to hear!
I had a similar issue today on my emonPi - all feeds stopped around 17:35 from the emonPi and 2 emonTH.
Looking at emonhub.log after a reboot, I saw that communication with /dev/ttyAMA0 was not ok:
2020-09-11 19:38:24,631 INFO MainThread Creating EmonHubJeeInterfacer 'RFM2Pi'
2020-09-11 19:38:24,633 DEBUG MainThread Opening serial port: /dev/ttyAMA0 @ 38400 bits/s
2020-09-11 19:38:26,636 WARNING MainThread Device communication error - check settings
2020-09-11 19:38:26,637 INFO MainThread Setting RFM2Pi baseid: 5 (5i)
2020-09-11 19:38:28,866 INFO MainThread EmonHub emonHub (emon-pi variant) v2.1.5
2020-09-11 19:38:28,867 INFO MainThread Opening hub...
2020-09-11 19:38:28,867 INFO MainThread Logging level set to DEBUG
2020-09-11 19:38:28,868 INFO MainThread Creating EmonHubJeeInterfacer 'RFM2Pi'
2020-09-11 19:38:28,871 DEBUG MainThread Opening serial port: /dev/ttyAMA0 @ 38400 bits/s
2020-09-11 19:38:30,874 WARNING MainThread Device communication error - check settings
2020-09-11 19:38:30,874 INFO MainThread Setting RFM2Pi baseid: 5 (5i)
2020-09-11 19:38:31,876 INFO MainThread Setting RFM2Pi frequency: 433 (4b)
2020-09-11 19:38:32,878 INFO MainThread Setting RFM2Pi group: 210 (210g)
2020-09-11 19:38:33,880 INFO MainThread Setting RFM2Pi quiet: 1 (1q)
2020-09-11 19:38:34,882 INFO MainThread Setting RFM2Pi calibration: 230V (1p)
Got it back to a working state by doing a UPDATE FIRMWARE ONLY from the Admin page, selecting ttyAMA0 and EmonPi.
Here is the update log:
Starting update via service-runner-update.sh (v3.0) >
- emonSD version: emonSD-17Oct19
- supported images: emonSD-24Jul20 emonSD-02Oct19 emonSD-17Oct19
- emonSD base image check passed...continue update
git pull /opt/openenergymonitor/EmonScripts
master
* stable
On branch stable
Your branch is up to date with 'origin/stable'.
nothing to commit, working tree clean
Already up to date.
Main Update Script
Date: Fri 11 Sep 20:23:05 EEST 2020
EUID: 1000
openenergymonitor_dir: /opt/openenergymonitor
type: firmware
firmware: emonpi
Hardware detected: EmonPi
Stopping emonPiLCD service
Display update message on LCD
EmonPi Firmware Update (Discrete Sampling)
Start ATmega328 serial upload using avrdude with latest.hex
Attempt: 1
avrdude -c arduino -p ATMEGA328P -P /dev/ttyAMA0 -b 115200 -U flash:w:/opt/openenergymonitor/emonpi/firmware/compiled/latest.hex
Note: progress written to logfile /var/log/emoncms/firmware.log
avrdude-original: Using autoreset DTR on GPIO Pin 7
strace: |autoreset: Broken pipe
ERROR: Not in sync
Attempt: 2
avrdude-original: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude-original: Device signature = 0x1e950f (probably m328p)
avrdude-original: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude-original: erasing chip
avrdude-original: reading input file "/opt/openenergymonitor/emonpi/firmware/compiled/latest.hex"
avrdude-original: input file /opt/openenergymonitor/emonpi/firmware/compiled/latest.hex auto detected as Intel Hex
avrdude-original: writing flash (18526 bytes):
Writing | ################################################## | 100% 2.63s
avrdude-original: 18526 bytes of flash written
avrdude-original: verifying flash memory against /opt/openenergymonitor/emonpi/firmware/compiled/latest.hex:
avrdude-original: load data flash data from input file /opt/openenergymonitor/emonpi/firmware/compiled/latest.hex:
avrdude-original: input file /opt/openenergymonitor/emonpi/firmware/compiled/latest.hex contains 18526 bytes
avrdude-original: reading on-chip flash data:
Reading | ################################################## | 100% 1.98s
avrdude-original: verifying ...
avrdude-original: 18526 bytes of flash verified
avrdude-original done. Thank you.
SUCCESS: flash verifed
waiting for emonpi to stop controlling LCD
Starting emonPi LCD service..
emonPi update done: Fri 11 Sep 20:23:23 EEST 2020
I was wondering if there is an explanation for this issue. In my case it just happened. I didn’t reflash the SD card, didn’t do any upgrades or anything else hours before it happened.
