I have an emonbase with 2 emontxV3 with nodeid 14 and nodeid 15.
hereby the result on the 2 scripts:
pi@emonpi:~ $ miniterm --rtscts /dev/ttyAMA0 38400
--- Miniterm on /dev/ttyAMA0 38400,8,N,1 ---
--- Quit: Ctrl+] | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H ---
--- exit ---
pi@emonpi:~ $ ls -lh /dev/serial*
lrwxrwxrwx 1 root root 7 Jun 30 07:17 /dev/serial0 -> ttyAMA0
lrwxrwxrwx 1 root root 5 Jun 30 07:17 /dev/serial1 -> ttyS0
pi@emonpi:~ $
and also the configuration as it worked till yesterday:
[[14]]
nodename = emontx1
[[[rx]]]
names = P1, P2, P3, P4, batt, Ptotal, temp1, temp2, temp3, temp4, temp5, temp6,temp7,temp8,temp9,temp10, temp11,temp12,temp13,temp14,temp15, temp16,temp17,temp18,temp19,temp20, temp21,temp22,temp23,temp24, pulse
scales = 0.77,0.77,0.77, 0.65, 0.01, 0.77, 0.1,0.1,0.1,0.1, 0.1, 0.1,0.1,0.1,0.1, 0.1, 0.1,0.1,0.1,0.1, 0.1, 0.1,0.1,0.1,0.1, 0.1, 0.1,0.1,0.1,0.1, 1
units = W,W,W,W, V, W, C,C,C,C,C, C,C,C,C,C, C,C,C,C,C, C,C,C,C,C, C,C,C,C, p
[[15]]
nodename = emontx2
[[[rx]]]
And the most recent emonhub log:
2020-06-30 07:46:44,449 INFO MainThread EmonHub emonHub emon-pi variant v3-beta
2020-06-30 07:46:44,450 INFO MainThread Opening hub...
2020-06-30 07:46:44,451 INFO MainThread Logging level set to DEBUG
2020-06-30 07:46:44,452 INFO MainThread Creating EmonHubJeeInterfacer 'RFM2Pi'
2020-06-30 07:46:44,456 DEBUG MainThread Opening serial port: /dev/ttyAMA0 @ 38400 bits/s
2020-06-30 07:46:46,459 WARNING MainThread Device communication error - check settings
2020-06-30 07:46:46,460 INFO MainThread Setting RFM2Pi baseid: 5 (5i)
2020-06-30 07:46:47,462 INFO MainThread Setting RFM2Pi frequency: 433 (4b)
2020-06-30 07:46:48,465 INFO MainThread Setting RFM2Pi group: 210 (210g)
2020-06-30 07:46:49,467 INFO MainThread Setting RFM2Pi quiet: 1 (1q)
2020-06-30 07:46:50,470 INFO MainThread Setting RFM2Pi calibration: 230V (1p)
2020-06-30 07:46:51,472 DEBUG MainThread Setting RFM2Pi pubchannels: ['ToEmonCMS']
2020-06-30 07:46:51,473 DEBUG MainThread Setting RFM2Pi subchannels: ['ToRFM12']
2020-06-30 07:46:51,475 INFO MainThread Creating EmonHubMqttInterfacer 'MQTT'
2020-06-30 07:46:51,479 DEBUG MainThread Setting MQTT pubchannels: ['ToRFM12']
2020-06-30 07:46:51,480 DEBUG MainThread Setting MQTT subchannels: ['ToEmonCMS']
2020-06-30 07:46:51,480 INFO MainThread Setting MQTT node_format_enable: 1
2020-06-30 07:46:51,481 INFO MainThread Setting MQTT nodevar_format_enable: 1
2020-06-30 07:46:51,482 INFO MainThread Setting MQTT nodevar_format_basetopic: emon/
2020-06-30 07:46:51,483 INFO MainThread Creating EmonHubEmoncmsHTTPInterfacer 'emoncmsorg'
2020-06-30 07:46:51,485 DEBUG MainThread Setting emoncmsorg pubchannels: ['ToRFM12']
2020-06-30 07:46:51,485 DEBUG MainThread Setting emoncmsorg subchannels: ['ToEmonCMS']
2020-06-30 07:46:51,486 WARNING MainThread Setting emoncmsorg apikey: obscured
2020-06-30 07:46:51,486 INFO MainThread Setting emoncmsorg url: https://emoncms.org
2020-06-30 07:46:51,487 INFO MainThread Setting emoncmsorg senddata: 1
2020-06-30 07:46:51,488 INFO MainThread Setting emoncmsorg sendstatus: 1
