I just run the update.
Hereby the log after the update.
The log stops at “restarting service-runner”, no lines more than up to there.
Starting update via service-runner-update.sh (v3.0) >
- emonSD version: emonSD-17Oct19
emonSD base image check passed...continue update
git pull /opt/openenergymonitor/EmonScripts
master
* stable
On branch stable
Your branch is up to date with 'origin/stable'.
nothing to commit, working tree clean
Already up to date.
Main Update Script
Date: Mon 29 Jun 07:04:39 BST 2020
EUID: 1000
openenergymonitor_dir: /opt/openenergymonitor
type: all
firmware: none
Hardware detected: rfm2pi
git pull /opt/openenergymonitor/emonpi
* master
On branch master
Your branch is up to date with 'origin/master'.
Fetching origin
Already up to date.
git pull /opt/openenergymonitor/RFM2Pi
* master
On branch master
Fetching origin
Already up to date.
Start emonhub update script:
emonHub update
git pull /opt/openenergymonitor/emonhub
git fetch --all --prune -v
Fetching origin
From https://github.com/openenergymonitor/emonhub
= [up to date] stable -> origin/stable
= [up to date] MQTTSubscriberInterfacer -> origin/MQTTSubscriberInterfacer
= [up to date] SDS011 -> origin/SDS011
= [up to date] emon-pi -> origin/emon-pi
= [up to date] env_example -> origin/env_example
= [up to date] lanip-status -> origin/lanip-status
= [up to date] master -> origin/master
= [up to date] redis_config_interface -> origin/redis_config_interface
= [up to date] unitless_decoder -> origin/unitless_decoder
git status
On branch stable
git pull origin stable
* branch stable -> FETCH_HEAD
Already up to date.
sudo: pip3: command not found
- Service ActiveState=active
Running emonhub automatic node addition script
[[5]]
Node 5 already present
[[6]]
Node 6 already present
[[7]]
Node 7 already present
[[8]]
Node 8 already present
[[9]]
Node 9 already present
[[10]]
Node 10 already present
[[11]]
Node 11 already present
[[12]]
Node 12 already present
[[13]]
Node 13 already present
[[14]]
Node 14 already present
[[15]]
Node 15 already present
[[16]]
Node 16 already present
[[19]]
Node 19 already present
[[20]]
Node 20 already present
[[21]]
Node 21 already present
[[22]]
Node 22 already present
[[23]]
Node 23 already present
[[24]]
Node 24 already present
[[25]]
Node 25 already present
[[26]]
Node 26 already present
Start emoncms update:
Update Emoncms Core
Checking status of /var/www/emoncms git repository
- git branch: stable
- no local changes
- running: git pull origin stable
Fetching origin
From https://github.com/emoncms/emoncms
Already up to date.
Update Emoncms database
Update Emoncms Services
emoncms_mqtt.service already installed
feedwriter.service already installed
service-runner.service already installed
Reloading systemctl deamon
Restarting Services...
- sudo systemctl restart feedwriter.service
--- ActiveState=active ---
- sudo systemctl restart emoncms_mqtt.service
- sudo systemctl restart emonhub.service
/opt/openenergymonitor/EmonScripts/sudoers.d/emoncms-rebootbutton: parsed OK
emonPi emoncms admin reboot button sudoers updated
Update Emoncms Modules
Updating /var/www/emoncms/Modules/app module
- git tags: 2.1.1-42-ge5d51a4
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/config module
- git tags: 2.0.5
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/dashboard module
- git tags: 2.0.7
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/device module
- git tags: 2.0.5
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/graph module
- git tags: 2.0.9
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/setup module
fatal: No names found, cannot describe anything.
- git tags:
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/wifi module
- git tags: 2.0.0-29-g274bcd5
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
/opt/openenergymonitor/EmonScripts/sudoers.d/wifi-sudoers: parsed OK
wifi sudoers entry updated
Updating /opt/emoncms/modules/backup module
- git tags: 2.2.2-6-g70894e1
- no local changes
Already up to date.
Already on 'stable'
Updating /opt/emoncms/modules/demandshaper module
- git tags: 1.2.4-5-gd689aae
- no local changes
error: cannot lock ref 'refs/remotes/origin/modular_forecasts': unable to resolve reference 'refs/remotes/origin/modular_forecasts': reference broken
From https://github.com/emoncms/demandshaper
! [new branch] modular_forecasts -> origin/modular_forecasts (unable to update local ref)
Already on 'stable'
Updating /opt/emoncms/modules/postprocess module
- git tags: 2.1.3-4-g5c50627
- no local changes
Already up to date.
Already on 'stable'
Updating /opt/emoncms/modules/sync module
- git tags: 2.0.5
- no local changes
Already up to date.
Already on 'stable'
Updating /opt/emoncms/modules/usefulscripts module
- git tags:
- git status:
On branch stable
Changes not staged for commit:
(use "git add <file>..." to update what will be committed)
(use "git checkout -- <file>..." to discard changes in working directory)
modified: integritycheck/integritycheck.php
no changes added to commit (use "git add" and/or "git commit -a")
Backup module installation and update script
- Loading EmonScripts config.ini
- Copying default.config.cfg to config.cfg
- Setting config.cfg settings
- Backup module symlink already exists
- PHP Version: 7.3
- Creating /etc/php/7.3/mods-available/emoncmsbackup.ini
post_max_size = 3G
upload_max_filesize = 3G
upload_tmp_dir = /var/opt/emoncms/backup/uploads
- phpenmod emoncmsbackup
- /var/opt/emoncms/backup already exists
- /var/opt/emoncms/backup/uploads already exists
- restarting apache
emonPi update done: Mon 29 Jun 07:05:18 BST 2020
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Mon Jun 29 08:17:59 2020 from 192.168.0.38
pi@emonpi:~ $
pi@emonpi:~ $ sudo apt update
Hit:1 http://archive.raspberrypi.org/debian buster InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
Reading package lists... Done
Building dependency tree
Reading state information... Done
1 package can be upgraded. Run 'apt list --upgradable' to see it.
pi@emonpi:~ $ sudo apt-get install -y python3-serial python3-configobj python3-p ip
Package python3-serial is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'python3-serial' has no installation candidate
E: Unable to locate package python3-configobj
Herrby the second result but still the same error:
Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:2 http://archive.raspberrypi.org/debian buster InRelease
pi@emonpi:~ $ sudo apt-get install -y python3-serial python3-configobj python3-pip
pi@emonpi:~ $
First if you paste terminal output or code please put 3 backticks (top left of keyboard) on a line before and 3 on a line after so it formats correctly (you can edit the post above).
Second - something isn’t right with apt. Have you changed anything?
Get:1 http://archive.raspberrypi.org/debian buster InRelease [32.6 kB]
Get:3 http://archive.raspberrypi.org/debian buster/main armhf Packages [330 kB]
Fetched 363 kB in 2s (173 kB/s)
pi@emonpi:~ $
