Emonhub fails to start - Unit var-log.mount not found
Hi there,
I’ve recently rebuilt my RPI running emonhub, but the service fails to start with the following message:
Failed to restart emonhub.service: Unit var-log.mount not found.
Not something I’ve seen before in my very limited linux experience, I’ve re-run the sudo ./install and copied in the full output below.
James
sudo ./install.sh
Apply raspberrypi serial configuration? 1=yes, 0=no:
You entered 1
Get:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15.0 kB]
Get:2 http://archive.raspberrypi.org/debian bullseye InRelease [23.6 kB]
Get:3 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [257 kB]
Fetched 296 kB in 2s (152 kB/s)
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
All packages are up to date.
python3-configobj is already the newest version (5.0.6-4).
python3-pymodbus is already the newest version (2.1.0+dfsg-2).
python3-serial is already the newest version (3.5~b0-1).
bluetooth is already the newest version (5.55-3.1+rpt1).
libbluetooth-dev is already the newest version (5.55-3.1+rpt1).
python3-pip is already the newest version (20.3.4-4+rpt1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: paho-mqtt in /usr/local/lib/python3.9/dist-packages (1.6.1)
Requirement already satisfied: requests in /usr/lib/python3/dist-packages (2.25.1)
Requirement already satisfied: pybluez in /usr/local/lib/python3.9/dist-packages (0.23)
Requirement already satisfied: py-sds011 in /usr/local/lib/python3.9/dist-packages (0.9)
Requirement already satisfied: sdm_modbus in /usr/local/lib/python3.9/dist-packages (0.5.1)
Requirement already satisfied: minimalmodbus in /usr/local/lib/python3.9/dist-packages (2.0.1)
Requirement already satisfied: pyserial>=3.0 in /usr/lib/python3/dist-packages (from minimalmodbus) (3.5b0)
Requirement already satisfied: pymodbus<3.0.0,>=2.4.0 in /usr/local/lib/python3.9/dist-packages (from sdm_modbus) (2.5.3)
Requirement already satisfied: six>=1.15.0 in /usr/lib/python3/dist-packages (from pymodbus<3.0.0,>=2.4.0->sdm_modbus) (1.16.0)
Requirement already satisfied: RPi.GPIO in /usr/lib/python3/dist-packages (0.7.0)
The user `emonhub' is already a member of `gpio'.
Unit /etc/systemd/system/[email protected] is masked, ignoring.
useradd: user 'emonhub' already exists
- installing emonhub.service
- Service ActiveState=failed
Do you get this output for this command?
pi@emonpi:~ $ sudo systemctl status var-log.mount
● var-log.mount - /var/log
   Loaded: loaded
   Active: active (mounted) since Sat 2022-02-26 05:17:42 GMT; 5 days ago
    Where: /var/log
     What: log2ram
    Tasks: 0 (limit: 2062)
   CGroup: /system.slice/var-log.mount
You say you rebuilt your RPi: can you outline how? Others may confirm or reject this, but emonhub.service may need its dependencies adjusting for a different setup.
Thanks @mjr,
Output as follows:
pi@emonhub:~ $ sudo systemctl status var-log.mount
Unit var-log.mount could not be found.
RPI re-build was a vanilla install of PiOS using the official raspberry Pi imager.
Cheers
James
OK, so I think I would do systemctl list-units and pick whatever one makes /var/log available, then systemctl edit emonhub.service and change var-log.mount to that.
The drawback of that will probably be that some future emoncms upgrade will break it the same way again.
Usually, I would add Alias=var-log.mount to some other systemd unit to communicate that /var/log is ready to emoncms in the way it expects, but the filesystem mounts seem to be generated automatically so I doubt that would work.
Just out of interest, why use vanilla PiOS instead of the emonSD distribution?
same issue on Ubuntu 20.04.3 LTS btw
i couldn’t find a systemd unit for /var/log on Ubuntu, so i used the root mount unit instead.
using
sudo systemctl edit emomhub.service --full
should read
sudo systemctl edit emonhub.service --full
[Edited as per correction below. Moderator (RW)]
i changed:
Requires=-.mount
After=-.mount network.target
after which emhub started succesfully
sudo systemctl start emonhub.service
-@emon:~/emonhub$ sudo systemctl status emonhub.service
● emonhub.service - emonHub data multiplexer
     Loaded: loaded (/etc/systemd/system/emonhub.service; enabled; vendor preset: enabled)
     Active: active (running) since Fri 2022-03-04 07:04:03 UTC; 7s ago
    Process: 61353 ExecStartPre=/bin/mkdir -p -m 0775 /var/log/emonhub/ (code=exited, status=0/SUCCESS)
    Process: 61354 ExecStartPre=/bin/chgrp -R emonhub /var/log/emonhub/ (code=exited, status=0/SUCCESS)
   Main PID: 61355 (python3)
      Tasks: 3 (limit: 4612)
     Memory: 23.1M
     CGroup: /system.slice/emonhub.service
             └─61355 python3 /usr/local/bin/emonhub/emonhub.py --config-file=/etc/emonhub/emonhub.conf --logfile=/var/log/emonhub/emonhub.log
Mar 04 07:04:03 emon systemd[1]: Starting emonHub data multiplexer...
Mar 04 07:04:03 emon systemd[1]: Started emonHub data multiplexer.
side note the install.sh from stable branch fails on ubuntu with
ERROR: launchpadlib 1.10.13 requires testresources, which is not installed.
solution:
sudo apt install python3-testresources
I only require the data sent via mqtt to my openhab instance so I’ve stuck with emonhub as opposed to the whole emonCMS stack.
Cheers
James
Excellent - that worked!
Thank you!
