5 posts were split to a new topic: Flashing the controller on linux
Apparently itâs available in TSSOP and SOIC versions. You need TSSOP.
Greetings Everyone, looks like I am late to the party.
I initially discovered this project a year ago, in a âGreat Scottâ YouTube video. As I get closer to building my 18650 packs my choice of a BMS has to be addressed. So I have started following these great BMS efforts much closer.
I am planning on using this system for my 840 cell 14s10p set of 6 packs.
My current questions involve the github repository concerning the best branch and tag to use this day, May 2, 2022.
The âdiyBMSv4â repository where the âMODULEV440â and âControllerCircuitâ reside, there are 2 branches, âmasterâ and âExperimental_2022Febâ. There are also multiple Tags. What is the preferred branch and tag to order from JLCPCB?
The âdiyBMS-CurrentShuntâ repository where the CurrentShuntCircuit reside, there are 2 branches, âmasterâ and âoptoisolator-changesâ. There are also multiple Tags. What is the preferred branch and tag to order from JLCPCB?
Thank you for reading this far.
Master is the currently supported version.
There are changes occuring all the time in some of the other branches, but they will get merged into master when they are ready.
V4.40 of the modules is the latest.
I have placed an order with JLCPCB. The Shunt order for 5 boards and assembly did not seem right. After my upload of gerber, bom and cpl, JCLPCB only lists the 3 components. Because I chose the top side not the bottom. Choosing the bottom side corrected the issue.
I apologize if this is the wrong place for this question. Disclaimer: I am a software engineer and e-bike enthusiast. I know just enough about hardware to make costly mistakes. Iâm learning, though.
Hereâs my situation: I have an e-bike of sorts (an Organic Transit ELF) that I have upgraded with a second motor. So, the original battery pack (with a 40A BMS) is insufficient. So, I built a Li-Ion 14sx4p battery pack consisting of 21700 cells that claim to be capable of 45A continuous discharge (Molicell INR-21700-P42A). So, at 4P, thatâs a theoretical output of 180A.
I only need about 80A, and I can (and do) control this with the motor controllers and a regulating computer (Cycle Analyst). There is also a 120A fuse on the battery pack itself, as a failsafe (well short of the 180A that the pack can theoretically handle).
So, maybe this is all I really need to do to protect myself from an over-current discharge problem? I am just accustomed to having the BMS also protect against exceeding a set discharge current limit.
The Cycle Analyst (CA) is clever about this, though. The throttle input goes to the CA, which has a configurable max discharge current, and the CA sends translated throttle signals to the two motor controllers. So, as the load approaches the max discharge current, the CA dials back the throttle signal to the controllers to prevent exceeding the current limit.
And, with the 120A fuse, maybe this is OK, and I donât need the BMS to be involved in limiting discharge current. Thoughts?
So, for my purposes, I would just need 14 monitoring modules and a controller. Yes?
Then, as Iâm understanding things so far, I have some decisions to make with regards to resistors and MOSFETs? Iâm just about a day or so into reading up on diyBMS, so am a little fuzzy on the details. Just looking for a basic sanity check to see that I am on the right track.
Cheers,
-B
Thank you for your quick reply. I need to adjust my battery design to your distributed BMS before I build my battery.
My battery design is for 48 Volts. I need to know if just ONE DiyBMS Monitor v4 can control 14 - 18650 Batteries connected in Series ? Peak voltage would be 58.8 Volts at 2.6 Amps. It looks like all examples Iâve seen show only 4.1 - 4.2 Volts for each Monitor. Any additional comments would be welcome.
Thanks again
Whatâs a âmonitorâ? diyBMS has modules (you need one per cell) and controllers (you need one per heap-of-batteries).
Hello,
thank you for your quick response. I am referring to the diyBMSv4/ModuleV440/.
I need to know if just ONE diyBMSv4/ModuleV440/ can control
Another question
Can 2 or more diyBMSv4/ControllerCircuit/ be connected to manage 1 large battery? This would reduce the number of diyBMSv4/ModuleV440/ managed by a single ControllerCircuit ?
Please ask any additional questions to help me grasp the BMS system requirements.
Thanks again
Easy:
No.
Howard. You don´t understand the function of the BMS system of Steward.
The controller board gets datas from the cell boards.
The controller tells the cell boards when they have to discharge current.
The cell board measures the voltage of the battery cell.
( It does not measure the whole battery. )
The battery voltage has to be that from a liion cell.
This is depending on the cell up to a max of 4.2V.
You cant control a line of 14 cells with one board.
You could control a parallel pack of 14 cells with a unique voltage up to 4.2
For a line of 14 cells you need 14 V4.40 cell boards.
You only need one monitor board. V4 of the small one or 4.2 of the 32 board.
The monitor can handle datas of up to 100 cell boards.
The cell boards are connected in a row.
At the beginning and the end of the row is the monitor. Its a circle.
Please checkout Stewards youtube videosâŚ
Thank you for your response.
If you would look at the youtube video of :
âDIYBMS V4 Introductionâ at âDIYBMS V4 Introduction - YouTubeâ at the time of 6:25.
The individual settings of the module are briefly discussed here. I donât understand what the maximum voltage that could be entered. I do understand what you are saying and I agree.
Although, I thought I should mention my thought, even if it was not well founded.
BTW, Who is Steward ? Are you referring to Mr. Stuart Pittaway, the developer of the diyBMS ?
Yes he is. I have seen the name âStewardâ instead of Stuart many times.
AutocorrectionâŚ
The complete System is based on 5V power.
The cell boards are designed to be powerded by one connection.
And this connection is also used to measure the voltage.
Any Idea what happens when you power one board with a row of 14S?
It goes bang The âmodulesâ are designed for 2.5V to 4.5V voltages.
If you have a 14S setup, then you would normally have 14 modules, each monitoring a cell (or a bunch of cells in parallel in the case of 18650âs).
If you donât have cell level monitoring, how are you going to balance the cells ?
Thats what I wanted to tellâŚ
As I have upgraded to the new v4.4 controller PCB I now have a spare fully assembled/tested v4.2 controller PCB from my original group buy a many months ago.
I also have a couple spare v4.4 controller PCBs which I can mostly assemble, I do not have the solid-state relays but I do have the rest of the parts.
All will be available as first come first served basis at $25 USD plus shipping (preferably only within US for shipping as international is crazy expensive)
Hello! Are they still available?
if i was to add r20 and the mosfet to a 4.2 board is there anything to stop that working as you said in your video the 4.4board has that added to improve communication
remove the 2.2k from the receive and then add it to the rx1 and then add in the r20 and the mosfet just using jumper wires and cutting into traces as such
