Did you see the recent YouTube video I did on this exact issue?
Thank you for the video, I have not seen it before,
Iāll change the resistor and if I still have issues Iāll do the foil shielding on the power leads as mentioned a few threads up
thank you
Hi together,
at first i would like to thank @stuart for this great product.
I finaly ordered a bunch of modules (5x controller ESP32 and 50x 4.40) and received them 2 days ago. Now i have seen on Github, that the resistor R16 had been exchanged a few days ago, so do i need to do the same on al my modules or will it run with the 4,7ohm?
No, you will be as is.
4 posts were split to a new topic: MQTT and ioBroker
CANåč®®1.0.pdf (612.8 KB)
Here is the can protocol from my hybrid Inverters.
Please see if you can implement.
Thanks!!
This protocol is pretty straightforward and it looks like only a handful of ID values are needed. What Iām not seeing in this doc is if the inverter will broadcast these or if the BMS should be sending/requesting these sort of CAN frames.
@stuart I believe we will need a pluggable CAN protocol as each inverter will potentially use a different set of ID values and byte/bit mappings.
thatās an excellent idea.
We know the values interpreted by each of our inverters (and if we cannot investigate them) we need a configurable panel in which to each field and value of the DIYBMS we can assign a specific position for the CAMBUS messages once the interpreter has been performed we can share the different interpreter settings. In the same way, the interpreter can be used for our batteries to emulate the Cambus messages of commercial batteries.
@stuart
@anyone
Few questions:
Is the MicroSD card socket necessary on the new esp32 controllers? And either way, what is its purpose? ( received the new controller pcbs the other day and was going to check one of them out this evening after work when I remembered I havenāt ordered any SD card sockets yet)
is there a tutorial of any sort or a guide on connecting a current sensor to the Esp8266 controller? I remember coming across some information Iām here a while back about what sensor people were using but not any information about hey, if it needs to be a particular type, if anything needs to be done so the information shows up on the DIYBMS, etcā¦
The sd card is optional, it allows local logging at greater detail than Mqtt etc.
Going forward is also allows firmware updates and saving of configuration.
Iāve not officially supported current monitoring on the old controller. I think a few people started looking at it, and I remember some code and ideas being shared.
Oh okay. Yeah I remember seeing something on here about it while back and I noticed that the controller board has 3 pads labeled current sense hey, so I just assumed
I guess for now Iāll have to use a separate device the monitor the current and send it to influxdb.
Oh by the way, how is the new current sensor pcbs / project coming along?
Very well, I keep forgetting to post the update on here, Iāve been keeping my patreons up to date!
Should hope to release in the next couple of weeks
hey there does anybody have one of the new version controller board over for sell ? There are actually 2 parts missing at JLCPCB
Annoying isnāt it! Iām trying to order some more boards, and every time, there is a different part missing!
I ordered 5 old controller boards and 20 cell module (in blue) last wednesday. Except the Atty, everything was available.
this is so sad they got other parts in 2300000000000000 pcs and some 0 i dont knowā¦
corona is NOT the issue ! Same problem long before on your version 2 xD
info from Mouser:
Verfügbarkeit
Lagerbestand:
0
Auf Bestellung:
10.573
verfügbar ab 12.10.2021
30.000
Erwartete Daten anzeigen
Lieferzeit ab Hersteller:
45
Wochen GeschƤtzte Produktionszeit des Werks für Mengen, die grƶĆer als angezeigt sind.
Lange Lieferzeit für dieses Produkt.
I ended up ordering from PCB way. They sourced parts from LCSC and other vendors. Some parts ended up coming from Digikey but those are through hole components.
Can you share the cost breakdown for parts? Iāve considered using PCBA from PCBWay but so far have only used their PCB/stencil services.
I got 5 controllers that included all surface mount components and most of the through holes ones (skipped due to an error on my end) for $280 USD. For the cell monitors I got 50 of them fully assembled for $624 USD. With shipping and bank fees my total was $904 USD.
Let me know if you want a deeper breakdown.
For the quality I an happy, I have an older DIYBMS from JLCPCB and feel the assembly is on par. Assembly time was a little longer because some parts took about 10 days to arrive.
From the time I put the order in to when it shipped was 20 days, that included a holiday and for them to review the order.
dude a little bit overpriced i guess
