LAST ENTRIES ON THE LOG FILE
2020-05-31 07:01:00.291|ERROR|demandshaper_model.php|Saved to disk
2020-06-01 07:01:00.321|ERROR|demandshaper_model.php|Saved to disk
2020-06-02 07:01:00.071|ERROR|demandshaper_model.php|Saved to disk
2020-06-03 07:01:00.315|ERROR|demandshaper_model.php|Saved to disk
2020-06-04 07:01:00.075|ERROR|demandshaper_model.php|Saved to disk
2020-06-05 07:01:00.160|ERROR|demandshaper_model.php|Saved to disk
2020-06-06 07:01:00.439|ERROR|demandshaper_model.php|Saved to disk
It looks like the /var/log is full
Server Information
Server Information
Services
  • emonhub :- Active Running
  • emoncms_mqtt :- Active Running
  • feedwriter :- Active Running - sleep 300s 12388 feed points pending write
  • service-runner :- Active Running
  • emonPiLCD :- Active Running
  • redis-server :- Active Running
  • mosquitto :- Active Running
  • demandshaper :- Active Running
Emoncms
Server
  • OS :- Linux 4.19.75-v7+
  • Host :- emonpi | emonpi | (192.168.1.215)
  • Date :- 2020-06-06 10:40:18 BST
  • Uptime :- 10:40:18 up 14 days, 22 min, 0 users, load average: 0.30, 0.54, 0.79
Memory
  • RAM :- Used: 22.82%
    • Total :- 975.62 MB
    • Used :- 222.68 MB
    • Free :- 752.94 MB
  • Swap :- Used: 41.22%
    • Total :- 100 MB
    • Used :- 41.21 MB
    • Free :- 58.78 MB
      Write Load Period
Disk
  • / :- Used: 49.46%
    • Total :- 3.92 GB
    • Used :- 1.94 GB
    • Free :- 1.79 GB
    • Write Load :- 1.2 KB/s (14 days 19 mins)
  • /var/opt/emoncms :- Used: 16.96%
    • Total :- 24.76 GB
    • Used :- 4.2 GB
    • Free :- 19.45 GB
    • Write Load :- 3.76 KB/s (14 days 19 mins)
  • /boot :- Used: 20.55%
    • Total :- 252.05 MB
    • Used :- 51.79 MB
    • Free :- 200.25 MB
    • Write Load :- 0 B/s (14 days 19 mins)
  • /var/log :- Used: 100.00%
    • Total :- 50 MB
    • Used :- 50 MB
    • Free :- 0 B
    • Write Load :- n/a
HTTP
  • Server :- Apache/2.4.38 (Raspbian) HTTP/1.1 CGI/1.1 80
MySQL
  • Version :- 5.5.5-10.3.17-MariaDB-0+deb10u1
  • Host :- localhost:6379 (127.0.0.1)
  • Date :- 2020-06-06 10:40:18 (UTC 01:00‌​)
  • Stats :- Uptime: 1210965 Threads: 23 Questions: 16610630 Slow queries: 0 Opens: 60 Flush tables: 1 Open tables: 54 Queries per second avg: 13.716
Redis
  • Version :-
    • Redis Server :- 5.0.3
    • PHP Redis :- 5.0.2
  • Size :- 817 keys (1.85M)
  • Uptime :- 14 days
MQTT Server
  • Version :- Mosquitto 1.5.7
  • Host :- localhost:1883 (127.0.0.1)
PHP
  • Version :- 7.3.11-1~deb10u1 (Zend Version 3.3.11)
  • Modules :- apache2handlercalendar Core ctype curl date dom v20031129exif fileinfo filter ftp gd gettext hash iconv json v1.7.0libxml mbstring mosquitto v0.4.0mysqli mysqlnd vmysqlnd 5.0.12-dev - 20150407 - $Id: 7cc7cc96e675f6d72e5cf0f267f48e167c2abb23 $openssl pcre PDO pdo_mysql Phar posix readline redis v5.0.2Reflection session shmop SimpleXML sockets sodium SPL standard sysvmsg sysvsem sysvshm tokenizer wddx xml xmlreader xmlwriter xsl Zend OPcache zlib
Pi
  • Model :- Raspberry Pi 3 Model B Rev 1.2 - 1GB (Sony UK)
  • Serial num. :- 43DDB2EE
  • CPU Temperature :- 60.15°C
  • GPU Temperature :- 60.1°C
  • emonpiRelease :- emonSD-17Oct19
  • File-system :- read-write
Client Information
Client Information
HTTP
  • Browser :- Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0
  • Language :- en-US,en;q=0.5
Window
  • Size :- 1903 x 966
Screen
  • Resolution :- 1920 x 1080
Do a search and you will find the answer. Latest update should solve it permanently.
Thanks, Found the update and ran the command from your post.
I also ran a full update and now the emonhub is broken. here is the config
[When quoting code etc, put three back-ticks on their own line before and after the code:
CODE
- Moderator (RW)]
#######################      emonhub.conf     #########################
### https://github.com/openenergymonitor/emonhub/blob/emon-pi/conf/emonhub.conf
#######################    emonHub  settings    #######################
[hub]
loglevel = DEBUG
# use_syslog = yes
[interfacers]
### This interfacer manages communication to BMW API for electric car monitoring
[[BMWi3]]
    Type = EmonHubBMWInterfacer
    [[[init_settings]]]
        timeinverval =600
        duringchargetimeinterval=60
        nodeid = 28
        tempcredentialfile = /tmp/bmwcredentials.json
        bmwapiusername = ****
        bmwapipassword = *****
    [[[runtimesettings]]]
        pubchannels = ToEmonCMS,
[[RFM2Pi]]
    Type = EmonHubJeeInterfacer
    [[[init_settings]]]
        com_port = /dev/ttyAMA0
        com_baud = 38400                        # 9600 for old RFM12Pi
        subchannels = ToRFM12,
        group = 210
        frequency = 433
        baseid = 5                              # emonPi / emonBase nodeID
        calibration = 230V                      # (UK/EU: 230V, US: 110V)
        quiet = true                            # Disable quite mode (default enabled) to enable RF packet debugging, show packets which fail crc
        # interval =  0                         # Interval to transmit time to emonGLCD (seconds)
[[MQTT]]
    Type = EmonHubMqttInterfacer
    [[[init_settings]]]
        mqtt_host = 127.0.0.1
        mqtt_port = 1883
        mqtt_user = emonpi
        mqtt_passwd = emonpimqtt2016
        pubchannels = ToRFM12,
        subchannels = ToEmonCMS,
        # emonhub/rx/10/values format
        node_format_enable = 1
        nodevar_format_enable = 1
[[emoncmsorg]]
    [[[init_settings]]]
        url = https://emoncms.org
        senddata = 1                    # Enable sending data to Emoncms.org
        sendstatus = 1                  # Enable sending WAN IP to Emoncms.org MyIP > https://emoncms.org/myip/list
        sendinterval= 30                # Bulk send interval to Emoncms.org in seconds
#######################          Nodes          #######################
[nodes]
## See config user guide: https://github.com/openenergymonitor/emonhub/blob/emon-pi/conf/emonhub.conf
[[5]]
    nodename = emonpi
    [[[rx]]]
        units = W,W,W,V,C,C,C,C,C,C,p
[[6]]
    nodename = emontxshield
    [[[rx]]]
       names = power1, power2, power3, power4, vrms
       datacode = h
       scales = 1,1,1,1,0.01
       units =W,W,W,W,V
[[7]]
   nodename = emontx4
   [[[rx]]]
      units =W,W,W,W,V,C,C,C,C,C,C,p
[[8]]
    nodename = emontx3
    [[[rx]]]
[[9]]
   nodename = emontx2
   [[[rx]]]
      datacode = h
[[10]]
    nodename = emontx1
    [[[rx]]]
       datacode = h
[[11]]
    nodename = 3phase
    [[[rx]]]
       names = powerL1, powerL2, powerL3, power4, Vrms, temp1, temp2, temp3, temp4, temp5, temp6, pulse
       scales = 1,1,1,1,0.01,0.1,0.1,0.1,0.1,0.1,0.1,1
[[12]]
    nodename = 3phase2
    [[[rx]]]
[[13]]
    nodename = 3phase3
    [[[rx]]]
[[14]]
    nodename = 3phase4
    [[[rx]]]
[[19]]
   nodename = emonth-water1
   [[[rx]]]
      names = Pulses since previous transmit, Total Pulses in previous 5 transmits for error check, Flow rate in period (ml/sec), Consumption in period (ml), Temperature 1
      datacode = h
      scales = 0.1,0.1,0.1,0.1,0.1,0.1,0
      units = P,P,P,P,C
[[20]]
   nodename = emonth2
   [[[rx]]]
      names = temperature, external temperature, humidity, battery
      datacode = h
      units = C,C,%,V
[[21]]
   nodename = emonth3
   [[[rx]]]
      datacode = h
      units = C,C,%,V
[[22]]
   nodename = emonth4
   [[[rx]]]
      datacode = h
      units = C,C,%,V
[[23]]
    nodename = emonth5
    [[[rx]]]
       names = temperature, external temperature, humidity, battery, pulsecount
       datacodes = h,h,h,h,L
       scales = 0.1,0.1,0.1,0.1,1
       units = C,C,%,V,p
[[24]]
    nodename = emonth6
    [[[rx]]]
       units = C,C,%,V,p
[[25]]
    nodename = emonth7
    [[[rx]]]
       units = C,C,%,V,p
[[26]]
    nodename = emonth8
    [[[rx]]]
       units = C,C,%,V,p
[[15]]
    nodename = emontx3cm15
    [[[rx]]]
        names = MSG, Vrms, P1, P2, P3, P4, E1, E2, E3, E4, T1, T2, T3, pulse
        datacodes = L,h,h,h,h,h,L,L,L,L,h,h,h,L
        scales = 1,0.01,1,1,1,1,1,1,1,1,0.01,0.01,0.01,1
        units = n,V,W,W,W,W,Wh,Wh,Wh,Wh,C,C,C,p
        whitening = 1
[[16]]
    nodename = emontx3cm16
    [[[rx]]]
        whitening = 1
[[5]]
    nodename = emonPi
    firmware = emonPi_RFM69CW_RF12Demo_DiscreteSampling.ino
    hardware = emonpi
    [[[rx]]]
        names = power1,power2,power1_plus_power2,Vrms,T1,T2,T3,T4,T5,T6,pulseCount
[[6]]
    nodename = emonTxShield
    firmware =emonTxShield
    hardware = emonTxShield
    [[[rx]]]
       names = power1, power2, power3, power4, Vrms
       datacode = h
       units =W,W,W,W,V
[[7]]
    nodename = emonTx_4
    firmware =V2_3_emonTxV3_4_DiscreteSampling
    hardware = emonTx_(NodeID_DIP_Switch1:OFF)
    [[[rx]]]
       names = power1, power2, power3, power4, Vrms, temp1, temp2, temp3, temp4, temp5, temp6, pulse
[[8]]
    nodename = emonTx_3
    [[[rx]]]
[[9]]
    nodename = emonTx_2
    firmware =V1_6_emonTxV3_4_DiscreteSampling
    hardware = emonTx_(NodeID_DIP_Switch1:ON)
    [[[rx]]]
       names = power1, power2, power3, power4, Vrms, temp1, temp2, temp3, temp4, temp5, temp6, pulse #Firmware V1.6
       #names = power1, power2, power3, power4, Vrms, temp                                           #Firmware =<V1.4 (un-comment)
       datacode = h
       scales = 1,1,1,1,0.01,0.1,0.1, 0.1,0.1,0.1,0.1,1 #Firmware V1.6
       units =W,W,W,W,V,C,C,C,C,C,C,p                   #FirmwareV1.6
       #scales = 1,1,1,1,0.01,0.1                       #Firmware =<V1.4 (un-comment)
       #units =W,W,W,W,V,C                              #Firmware =<V1.4 (un-comment)
[[10]]
    nodename = emonTx_1
    [[[rx]]]
       datacode = h
[[11]]
    nodename = 3phase
    [[[rx]]]
[[12]]
    nodename = 3phase2
    [[[rx]]]
[[13]]
    nodename = 3phase3
    [[[rx]]]
       units = W,W,W,W,V,C,C,C,C,C,C,p
[[14]]
    nodename = 3phase4
    [[[rx]]]
[[15]]
    [[[rx]]]
        whitening = 1
[[16]]
    [[[rx]]]
        whitening = 1
[[19]]
    nodename = emonTH_1
    firmware = emonTH_DHT22_DS18B20_RFM69CW
    hardware = emonTH_(Node_ID_Switch_DIP1:OFF_DIP2:OFF)
    [[[rx]]]
       datacode = h
       units = C,C,%,V
[[20]]
    nodename = emonTH_2
    hardware = emonTH_(Node_ID_Switch_DIP1:ON_DIP2:OFF)
    [[[rx]]]
       datacode = h
       units = C,C,%,V
[[21]]
    nodename = emonTH_3
    hardware = emonTH_(Node_ID_Switch_DIP1:OFF_DIP2:ON)
    [[[rx]]]
       datacode = h
       units = C,C,%,V
[[22]]
    nodename = emonTH_4
    firmware = V1_5_emonTH_DHT22_DS18B20_RFM69CW
    hardware = emonTH_(Node_ID_Switch_DIP1:ON_DIP2:ON)
    [[[rx]]]
       datacode = h
       units = C,C,%,V
[[23]]
    nodename = emonTH_5
    firmware = V2.x_emonTH_DHT22_DS18B20_RFM69CW_Pulse
    [[[rx]]]
       names = temperature, external temperature, humidity, battery, pulseCount
       units = C,C,%,V,p
[[24]]
    nodename = emonTH_6
    [[[rx]]]
       units = C,C,%,V,p
[[25]]
    nodename = emonTH_7
    [[[rx]]]
       units = C,C,%,V,p
[[26]]
    nodename = emonTH_8
    [[[rx]]]
       units = C,C,%,V,p
[[5]]
    nodename = emonPi
    hardware = emonpi
    [[[rx]]]
[[6]]
    [[[rx]]]
       datacode = h
       units =W,W,W,W,V
[[7]]
    nodename = emonTx_4
    [[[rx]]]
[[8]]
    nodename = emonTx_3
    [[[rx]]]
[[9]]
    nodename = emonTx_2
    [[[rx]]]
       datacode = h
[[10]]
    nodename = emonTx_1
    [[[rx]]]
       datacode = h
[[11]]
    nodename = 3phase
    [[[rx]]]
[[12]]
    nodename = 3phase2
    [[[rx]]]
[[13]]
    nodename = 3phase3
    [[[rx]]]
[[14]]
    nodename = 3phase4
    [[[rx]]]
[[15]]
    [[[rx]]]
        whitening = 1
[[16]]
    [[[rx]]]
        whitening = 1
[[19]]
    nodename = emonTH_1
    [[[rx]]]
       datacode = h
       units = C,C,%,V
[[20]]
    nodename = emonTH_2
    [[[rx]]]
       datacode = h
       units = C,C,%,V
[[21]]
    nodename = emonTH_3
    [[[rx]]]
       datacode = h
       units = C,C,%,V
[[22]]
    nodename = emonTH_4
    [[[rx]]]
       datacode = h
       units = C,C,%,V
[[23]]
    nodename = emonTH_5
    [[[rx]]]
       units = C,C,%,V,p
[[24]]
    nodename = emonTH_6
    [[[rx]]]
       units = C,C,%,V,p
[[25]]
    nodename = emonTH_7
    [[[rx]]]
       units = C,C,%,V,p
[[26]]
    nodename = emonTH_8
    [[[rx]]]
       units = C,C,%,V,p
Need a tad more info than this (logs error messages etc). Probably not the config but did you look to see if anyone else had posted about emonhub issues in the last day or so? Something like this…
And a fix…
(running the update again won’t fix it I am afraid).
Hi @borpin
I did have a look first.
the emonhub was error at line 257. if you look at my emonhub config its been added too twice from node [[5]]
Great - useful to say the error is different.
Can you post the actual error please. The config looks fine.
I did not save the log file.
If you look at my config file they are 3 node [[5]] this cause it to fall over.
Just delete the extra, repeated nodes - @TrystanLea something odd happening?
I had a same issue a few weeks back (config file node definitions were completely duplicated). The day before , we had a storm and the power went off for a second or two. When I noticed some issues ( feeds not appearing in my other monitoring systems I just thought I should do a controlled shutdown and reboot. (I have a few RasPies and sometimes the time etc gets a bit out of whack if they initialise before the internet router resumes after a power failure) … Anyway I noticed some strange ‘Updating’ message on the EmonPi LCD screen when rebooting and thought that’s strange, not seen that before.
Spent a frustrating few hours problem solving, looking here. Thought for a while it was log files filling for a while … eventually found the emonhub config file duplicate nodes ???
Had backups so just deleted the duplicates and all is now fine.
Sorry I have no logs or notes, but at the time I thought it was a local issue here.
Dont log on here a lot so when I saw this entry I now suspect there is a hidden issue that is lurking in the code that is waiting for some sequence of events.
Thanks this is what I saw with @glyn.hudson’s systems but couldnt seem to replicate in further testing so thought it might a one off, clearly a more common issue, and interesting that you saw the same issue @muzza a couple of weeks ago prior to the recent emonhub update.
I will take a look at it in more detail.
Looks like the emonhub.conf duplicate nodes issue is a recurring issue, here’s a post from 2016 Emonhub.conf duplicate node decoders after update - #24 by whitecitadel @whitecitadel suggests:
I dont think a full data partition would have caused the issue for @glyn.hudson and if I try filling the /var/log /var/tmp or /tmp partitions the script appears to work fine. Can anyone else think why this line might fail:
if ! grep "\[$var\]" $emonhub_location; then
its looking for the entry [nodeid] in the emonhub.conf file, if it cant find one it will add the node to emonhub.conf.
The answers speak specifically to using ! grep
First thought - the verbosity of the comments that explain what this script is doing blew me away :thinking:
If someone adds a comment to the file that has the string [5] in it it would fail for that node…
Initial suggestion … more robust would be (I think)…
  if grep "^\[\[$var\]\]" $emonhub_location; then
    echo "Node $var already present"
  else
    if [ -f $path/$var ]; then
      echo "">>$emonhub_location
      cat $path/$var >> $emonhub_location
      echo "Added node $var to emonhub.conf"
    fi
  fi
Is this an old format for the nodes?
$homedir/emonhub/conf/nodes
Improvements;
  1. If the folder $homedir/emonhub/conf/nodes doesn’t exist, nothing is done anyway so check for that first.
  2. Once the folder at $homedir/emonhub/conf/nodes has been used it should never be needed again so remove it so next time condition 1 causes an exit.
Yes I as far as I recall the backups were making /home/pi/data quite full then the upgrade filled up the space - I had the exact issue with duplicate nodes in the config, once removed all was well.
Scripted something later to move the backups off the pi SD card to my NAS each week and ensure it doesn’t creep to full.
I did have additional entries added to support my SMA inverter, but apart from that the config was as per default. Not done it since, but I think I am running now about 12 month old code at least, probably time to try another update (after checking the backups!)
Interesting, I’ve had a look and /var/log is indeed full, however there is plenty of space on the disk so there should be space in /data (/var/opt/emoncms).
df -h
Filesystem      Size  Used Avail Use% Mounted on
/dev/root       4.0G  2.7G  1.1G  72% /
devtmpfs        484M     0  484M   0% /dev
tmpfs           488M     0  488M   0% /dev/shm
tmpfs           488M   56M  433M  12% /run
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           488M     0  488M   0% /sys/fs/cgroup
tmpfs           1.0M  4.0K 1020K   1% /var/lib/php/sessions
tmpfs           1.0M     0  1.0M   0% /var/tmp
tmpfs            30M   12K   30M   1% /tmp
/dev/mmcblk0p3   10G  1.7G  7.9G  18% /var/opt/emoncms
/dev/mmcblk0p1  253M   53M  200M  21% /boot
log2ram          50M   50M     0 100% /var/log
tmpfs            98M     0   98M   0% /run/user/1000
I can replicate the nodes duplicating issue each time I run an update or reboot. The update seems to run on each reboot.
Most of the space in /var/log is being taken up by logrotate
du -h /var/log/
0       /var/log/supervisor
0       /var/log/redis
0       /var/log/private
0       /var/log/mysql
0       /var/log/mosquitto
44M     /var/log/logrotate
72K     /var/log/emonpilcd
5.7M    /var/log/emonhub
12K     /var/log/emoncms
28K     /var/log/apt
0       /var/log/apache2
50M     /var/log/
Specifically /var/log/logrotate/logrotate.log which is 44Mb. It seems logrotate is not rotating itself!
The system will eventually stop updating.
Yes I raised the issue in April and put in a fix a while ago…
This will tell you the largest files.
sudo du -a /var/log/* | sort -n -r | head -n 30
On update, if /var/log/ is full it cannot solve the problem as there is no space to do the rotation.
Fantastic, I already had your update pulled in. However, since /var/log was already full it wouldn’t run the update via the web interface. After running:
sudo truncate -s 0 /var/log/logrotate/logrotate.log
The update was able to run and emonub duplicates nodes were not added :smiley:
I wonder what the solution to avoid this catch 22 is? I saw your suggesting regarding adding the truncate command to the update script. However, the update script would not be able to run to pull in and execute the ‘truncate’ command since the /var/log is full? Maybe we need to detect if /var/log is full and temporarily use another location for emonpiupdate.log to allow the update to run?
You could make that the first thing the script does before trying anything else. So the du on the /var/log folder to find the biggest file and truncate it?
Good idea, I’ve added a note to your git issue with this suggestion to discuss with @TrystanLea
That works well for me, I’ve applied this initial fix improved emonpi_auto_add_nodes script implementation thanks to @borpin · openenergymonitor/emonhub@14c774c · GitHub
