The WiFi setup on the emonPi has never supported captive portal and can be quite involved to maintain.
I’ve just tested out this captive portal based WiFi setup manager on a RaspberryPi 3B+ running Stretch
Works really well, to install run:
bash <(curl -L https://github.com/balena-io/wifi-connect/raw/master/scripts/raspbian-install.sh)
Then to start run:
$ sudo wifi-connect --portal-ssid WiFiTest
The start command could be started by a script that checks for wifi connectivity like this one: wifi-connect/start.sh at master · balena-os/wifi-connect · GitHub
An example of using WiFi Connect in a docker based Python project can be found here: GitHub - balena-io-playground/balena-wifi-connect-example: Example application to demonstrate balena-wifi-connect
This post is just to document this test, we have no immediate plans to deploy this on the emonPi but good to know for future developments.
