DemandShaper new device integration
I’m a total NOOB to OpenEnergyMonitor having just set up a base installation of Emoncms on using the Pi SD image. My main use case is to leverage DemandShaper to allow me to make use of Octopus Agile rates to start/stop an immersion heater (later I will look into OpenEVSE and other use cases). I am using a Sonoff Pow R2 device flashed with Tasmota and have setup Node-RED for MQTT message routing/manipulation. Is there an MQTT or other API I can follow to allow the device to appear in DemandShaper?
I have read about the messages that will be sent from DemandShaper to the device but not the handshaking at device pairing etc…
The demand shaper process publishes the schedule configuration to a MQTT topic that the device subscribes to, e.g:
emon/smartplug1/in/ctrlmode On/Off/Timer
emon/smartplug1/in/timer 1300 1600
Any help would be appreciated.
If you use a base topic of emon/, emoncms will read that topic back in (you will see it on the inputs page). It is better to publish on a different topic to the receipt topic.
I don’t think there is such a thing - it is just the passing of MQTT messages.
However, I’m not familiar with DemandShaper itself.
If this was done on the same Pi, this may cause issues - just so you are aware.
You can use Tasmota rules to do some of the topic manipulation I believe.
You can manage your Tasmota devices through tdmgr.
Thanks, @borpin, that’s all clear. I’ve managed to publish the status from the Tasmota device in to Emoncms but it’s the DemandShaper application that appears to be a mystery to integrate with. The worst case would be for me to pull the code from GitHub and reverse engineer the API used - I was hoping it was clearly documented somewhere as it appears to be a great feature to leverage.
rotfllmao
I think there may be a post here on DemandShaper. Emoncms Demand Shaper module
Thanks, I’ve read that post and would be good if I were to flash the device to the bespoke firmware but I was hoping to keep it setup as Tasmota and integrate it with software. It does give me an alternative option if there is no other way.
@TrystanLea - would be good to easily interface to Tasmota - shouldn’t be too hard the topic structure is pretty common.
@agamos, If you have NR setup, then just read the DemandShaper output topic and send appropriate commands to the Tasmota device.
@borpin, yes, I’ll take that approach. After re-reading that post I just noticed the UDP discovery packet sent out. I’ll check through the code, find the expected response and work progressively through. All being well I’ll have a NR flow that I can share later. Thanks for your advice.
The UDP side of things is optional, it’s just there to simplify the initial setup with EmonESP, the OpenEVSE EV charger integration does not make use of / implement this so you can make it work without it.
This python based smartplug simulator might be useful to help with development:
demandshaper/smartplug_sim.py at master · emoncms/demandshaper · GitHub
