After replace another microsd card on raspberry pi (3 time), I make the emoncms fresh install and use an old backup to retrieve all configuration.
The backup works well (thanks) but now I try to config dataplicity to use the “same” installation and wormwhole, because I have some devices using this external URL.
I can create a new device in dataplicity and delete the existent, but the wormwhole / URL will be different.
I don’t have the initial installation line code, but is possible to find the information in dataplicity ?
So, if I understand well, in case of reinstallation, inclusive if I have the same installation command line “xxxxxx5y.py”, dataplicity will generate another external UR for the same device.
It’s not possible to maintain the same URL in case of reinstall.
In dataplicity I can’t retrieve again the curl command for the already installed raspberry pi.
I asked Dataplicity if there’s a way to re-install Dataplicity and keep the same wormhole URL. They replied “Yes you can, all you need to do is to copy/paste the existing serial and auth files from /opt/dataplicity… directory onto the new OS prior to installation.” I’ll give this a try later this week.
That’s nice to know. It would be nice to be able to specify the URL, they dont always sound that right, mine currently sounds like an insult, not a URL you’d want to give to a client if you where provisioning systems…
