Hi @Radoslav_dataplicity, are you directly affiliated with Dataplicity? Are you a dev or maintainer? Are you here to offer support or just promoting Dataplicity?
Have you seen the many threads here on the forum for Dataplicity?
If you check /etc/rc.local on your emonPi/emonSD you find the Dataplicity log files are recreated at boot time to counter the fact all log files are lost on reboot as they are held in RAM on this read-only image. Unless Dataplicity (or Supervisor) have altered the way the log files are only created at installation and never tested for after that, your installation above would have failed following a reboot.
Are you able to confirm if this issue has now been resolved in Dataplicity?
@barfle (Elliot Mackenzie) said back in January that they were working on a solution.
