The steps below show how to access your emonPi remotely
1. Use SSH to access the terminal on emonPi.
2. Create an account with dataplicity.
3. Run the installation command.
4. Log in to your account and access your device remotely.
Hi @Radoslav_dataplicity, are you directly affiliated with Dataplicity? Are you a dev or maintainer? Are you here to offer support or just promoting Dataplicity?
Have you seen the many threads here on the forum for Dataplicity?
If you check /etc/rc.local on your emonPi/emonSD you find the Dataplicity log files are recreated at boot time to counter the fact all log files are lost on reboot as they are held in RAM on this read-only image. Unless Dataplicity (or Supervisor) have altered the way the log files are only created at installation and never tested for after that, your installation above would have failed following a reboot.
Are you able to confirm if this issue has now been resolved in Dataplicity?
@barfle (Elliot Mackenzie) said back in January that they were working on a solution.
Hey @pb66 Iām part of Dataplicity and Iām here to offer support. I did see the other threads on this forum and I was hoping that by starting this one I could solve problems such as the one with the logs.
I have my emonPi here beside me and have done multiple reboots after going through the installation steps above. Everything works fine and emonPi is still connected.
I believe it is only working after a reboot because we have already put a rough fix in rc.local. I believe your guide and installation script would not work without those changes that were there prior to you calling your install script. This fix is less than ideal but this workaround is needed for Dataplicity to function on an emonSD.
Can you confirm if there has been any progress on this issue?
If you remove "supervisor/supervisord.log" from lines 12 and 13 of /etc/rc.local and remove/comment out line 20 completely does it still work after a reboot?
I have made the adjustments as you suggested and emonPi is still visible online on dataplicity device list after a reboot. Would you like to give it a try as well if you donāt mind ?
Thanks for testing. I donāt have an emonPi up and running right now. But it sounds like the issue might have been addressed, the only way to be sure would be to start with a fresh image and remove those bits from rc.local before running the install script and then check the log files after a reboot. Unless of course, you know specifically that this has been addressed.
Can you check if /var/log/supervisor/supervisord.log is there with the right ownership and permissions after rebooting.
Hi Paul,
Unfortunately weāve just confirmed that your rc.local fix is still requiredā¦
The issue here stems from [feature request] options to deal with bad logging situation Ā· Issue #709 Ā· Supervisor/supervisor Ā· GitHub. Dataplicity uses supervisor, but unfortunately upstream has concluded that this is a fix for the distribution, not for supervisor (I can see the point, though I donāt entirely agree with the conclusion). It does also appear that you have discovered a number of other packages that exhibit the same behaviour here - nginx, logrotate etc.
My question for you is what do you think is the correct solution for emonpi here? Short of a fix in the Raspbian repositories, is your fix here adequate do you think, or should we ask the Raspbian guys politely if they will adjust this in their distribution? Note that in general /var/log on Pi is not on tmpfs, and that the adjustment to tmpfs, while common, is in this case particular to the distribution/setup of emonpi.
Best,
Elliot.
Hi Elliot, discussions keep popping up about this, the latest is on the āMosquitto won't start on boot after raspbian and emonsd updateā thread.
Whilst I firmly believe itās in the hands of the SW providers to make their offerings as robust as possible and being able to overcome a deleted/moved log file would benifit their SW, I also understand we are unlikely to persuade the likes of MySQL, Redis and Apache2 to adopt a change so I also believe it to be a part of the RO optimizations to accommodate this anomaly that exists when moving the log files to tempfs. I do not like the idea of hard coding each SWās requirements into the emonPi image, but that is how it is done at the moment.
IMO the read-only optimisations should include something to automate the process of replicating any additional log files at boot time regardless of the SW they belong to.
The reason I brought it up here was firstly for clarification as to whether that was still the case, and secondly to make it clear that following the guide outlined in the first post is dependent on the pre-existing āfixā (although I do not think this is a proper fix as the use of rc.local in this way is not recommended and it is depreciated in Stretch) just in case someone lands here via a different route, for example if they partially follow the self-build guide for the emonSD image they may well not have those entries in rc.local.
The guide (although clear and very helpful) only suits pre-built emonSD or non-read-only setups, additional steps are required if installed on a home-brew read-only OS based setup to ensure the logfiles are present before Supervisord service runs.
It would have been nice to have one less SW to worry about, but itās not the end of the world as we have to accommodate others too as you point out.
Thanks @Radoslav_dataplicity
Iāve also tested setting up dataplicity using our off-the-shelf latest emonPi SD card image emonSD-26Oct17. It works great. All the issue mentioned above have been resolved.
If you donāt mind I will use these screenshots to post up a blog post and user guide page for how to use and setup dataplicity for remote access.
By all means
Please let us know if and when we can be of further assistance.
Best,
Elliot.
Iāve just create a page on our user guide detailing how to setup Dataplicity an an emonPi:
Please let me know if you spot any errors.
Note: Iāve just pushed up the page, it will take about 5min from when I post this for the link to go live!
Glyn,
Hi, Iāve probably got the complete wrong end of the stick. I was hoping this would let me see my local emoncms dashboard. From what Iāve seen I donāt think this is so? if that is the case should I uninstall Dataplicity?
John
Yes it will, you will need to enable a duplicity āwormholeā to give you https access to your local emonPi. See the guide linked above.
Thats great, got it to work. Thanks
John
Sorry to bring back the topic but i have a question about dataplicity and emoncms android app.
Using Dataplicity, am i able to use the android emoncms app to see the consumption of my emonpi?
The emoncms app should work fine using a dataplicity āwormholeā. The app doesnāt use any special api calls.
Iām confused. Why would you use SSH and then hand stuff over to a 3rd party? You may as well use telnet. Itās not clear if dataplicity is a ādyndnsā style redirector or a proxy? If the former, then great but if the later then people need to understand that their data is no longer secure.
Thanks Paul! Going to try it soon.
Actually, its one of the things that is keeping me away from using it.
I am trying to find (to be honest) a way to use emoncms outside of my home network and keep away of another montly bill, in this case, on the raspberry pi that i have installed in my brotherās house.
In my emonpi, with all the purchases that i have made and the ones that i will in the future, i will, for sure have 4 or 5 years on emoncms.org, but not my brother. So, i was trying to find a way to avoid negative balance on emoncms.org.
@glyn.hudson:
Did the oficial stable emoncms android app should have the Portuguese translation? I got out from Beta Testing and found that the latest stable version in google play is 2.0.9 with date 14/07/2017 and portuguese is not present.
From Dataplicity web site.
Dataplicity connects using client-initiated HTTPS, so itās safe, encrypted and you donāt need to make specific firewall exceptions.
Uh huh. So, you trust them with your private data that would otherwise be end-to-end protected between devices you control using SSH then? Cool.
