Command Line Cheatsheet
If you’d like to add your own command line tip please reply to this post
How to login to the raspberry pi via terminal (SSH)
ssh pi@*** (*** = or IP-address from Pi or domain name)
Password = emonpi2016 (standard password if you didn’t change it)
Connecting via ssh
Safely shutdown or reboot a raspberry pi
after you logged in via SSH you can issue these commands
shutdown :
sudo shutdown -h now
-or-
sudo poweroff
reboot :
sudo shutdown -r now
-or-
sudo reboot
Factory Reset
Factory reset can be made by connecting via ssh then running:
sudo su
~/emonpi/./factoryreset
Warning - destroys all data!
Troubleshooting — OpenEnergyMonitor 0.0.1 documentation
Maintain crontab files
List cron for user Pi
crontab -l -u pi
List cron for root
sudo crontab -l
Edit cron for user Pi *
crontab -e -u pi
Edit cron for root *
sudo crontab -e
* for low-write emon devices, use rpi-rw to unlock filesystem and allow write access.
Determine emonSD image version
ls /boot | grep emonSD
Display_PHPfina_Feed_Interval
To determine feed interval and start time of feed.
cd /home/pi/data/phpfina
od -i 1.meta
response:
0000000       0       0       10     1435712370
0000020
10 is interval in seconds
1435712370 is start time in unix epoch
Submitted by chaveiro on Mon, 27/07/2015 - 12:30
Get status of all Services
Runs all init scripts, in alphabetical order, with the status command. The status is:
[ + ] for running services
[ - ] for stopped services and
[ ? ] for services without a ‘status’ command
sudo service --status-all
#emon Node-RED
including npm & node.js
Status or Restart of Node-RED Service
Use the below commands to get the status or restart Node-RED
sudo service nodered status
sudo service nodered restart
Version number of Node-RED
npm show node-red version
npm show node-red version -g
Node-RED items in syslog
Display Node-RED items saved in syslog
sudo cat /var/log/syslog | grep "Node-RED"
Output Node-RED items in syslog
sudo tail -f /var/log/syslog | grep "Node-RED"
Version of npm
npm is used for installing installing nodes for Node-RED
npm -v
sudo npm -v
List user installed Nodes with version info
run command from the Node-RED install directory
cd /home/pi/.node-red
npm list -g | grep emoncms
npm list | grep emoncms
Upgrade of NPM version 1.x to version 2.x *
sudo npm install -g [email protected]
logout
Check for outdated Node-RED npm packages
npm outdated --prefix ~/.node-red
-or-
cd ~/.node-red
npm outdated
to check for outdated global npm packages:
npm outdated -g
Version of node.js
node -v
sudo node -v
Check if Redis is running
redis-cli PING
If running, the response should be “PONG”
Flush Redis
redis-cli flushall
#emon mySQL
Access mySQL database
for advanced users only (this leaves me out!)
mysql -u emoncms -p emonpiemoncmsmysql2016 emoncms
Show emoncms tables
mysql> show tables;
Display Feed info
Display ID number, feed id Name, Tag for feed, Datatype (realtime, daily, etc), Public (or private), Size of feed, Engine used for feed (phpfina or phptimeseries, etc.), and Process List for all Feeds
mysql> select * from feeds;
#Miscellaneous
Selectively monitor log file in real time
Display new lines with a string (e.g., “NEW FRAME : OK 5”) in the emonhub.log file:
tail -f /var/log/emonhub/emonhub.log | grep "NEW FRAME : OK 5"
Selectively display log file
Display all lines with a string (e.g., “NEW FRAME : OK 5”) in the emonhub.log file:
cat /var/log/emonhub/emonhub.log | grep "NEW FRAME : OK 5"
Display all lines with two strings (e.g., “mqtt” or “mosquitto”) in the syslog file:
cat /var/log/syslog | grep -ie mqtt -e mosquitto
Thank you to @Paul, @bidouilleur, @Bill.Thomson, @Robert.Wall, @glyn.hudson, @pb66 for their help in creating this post.
Resetting the emonCMS password
Can be done locally, or via SSH.
This assumes your emoncms admin account user name, and your database, are both named emoncms. If not, substitute your admin account username where you see the emoncms username, and your database name where you see the emoncms database name.
Create a new user from the emoncms login screen. For this example, we’ll give that user the name emontemp.
Take note of the password you gave the emontemp user.
Run Mysql as the MySQL root user:
mysql -u root -p (you’ll be prompted for the MySQL root user password)
Switch to your database. Substitute your database name if it’s not emoncms.
use emoncms
Copy emontemp’s password to the emoncms user account:
update users set password=(select * from (select password from users where username='emontemp') x) where username='emoncms'; (Substitue your username if it’s not emoncms.)
Copy emontemp’s password salt to the emoncms user account:
update users set salt=(select * from (select salt from users where username='emontemp') x) where username='emoncms';
Time saver tip: The two commands are the same save for the words password and salt. After you issue the first command, hit the up arrow key, change the two instances of password to salt, hit enter.
That’s it. You should be able to log on to your emoncms admin account with the password you gave emontemp.
Permanently authorising a connection to the emonPi
By creating a pair of Key Files - one on the emonPi and one on the machine you use to access it, you can remove the need to type a password each time you access the emonPi via SSH.
Note: this authorises the machine and whoever is using it to access the Pi, as distinct from a person who knows the password who is using the machine.
  1. Enable SSH on the emonPi / emonBase. For the emonPi only, use front panel LCD menu & pushbutton. Alternatively, for both (and the only way for the emonBase), add an empty file named “ssh” in the root partition.
  2. You must have SSH & SCP on the computer that’s being used.
  3. Generate a SSH key pair with “ssh-keygen” Don’t set a password - this authorises the MACHINE (vs the user] to update the emonPi / emonBase.
  4. This will generate the key files, in /home/[your user name]/.ssh
    The private key file, which you must keep secure, is id_rsa
    The public key file is id_rsa.pub
  5. Copy to the Pi with ssh-copy-id [remote id]
    e.g.remote-id = ‘[email protected]’,
    The SSH password “emonpi2016” is required this time only.
The SSH password will not be required again, unless you re-flash the SD card - in which case, repeat step 5 with the new SD card. You can use the same pair of key files with many emonPi’s, if you wish.
If you use puTTY,
