So, now seriously looking at moving away from our existing Combi.
Obviously with the Combi, not hot water cylinder for DHW.
Looking at costs, for the price of a hot water cylinder it’s not too far a leap to go to an IHP Cylinder. Wondering what peoples thoughts are on advantages and disadvantages of this.
iHP Cylinder for hot water, and ASHP for space heating using existing rads.
If you’re planning on getting the BUS grant, then getting an HP cylinder may limit your choices.
The only company that I’m aware of that offer the sort of dual heat pump setup you describe under the BUS grant is Adlår Castra, and DESNZ makes them duct the cylinder heat pump to outside (because that’s how the legislation is worded). Having said that I don’t think there would be anything to stop you rerouting it at a later date to give you some modest summer cooling and dehumidification too.
So assume you are staying with the gas boiler (just reread your original post and you say ASHP). Cylinders with their own heat pump are available, but not all are equal or always good value. Look at cylinder material especially as some are coated carbon steel with anode - avoid. Haier make one that looks good value - Available from Wolesely. But if you room for one of these you also have room for a normal heat pump cylinder as they are smaller. Also be aware of the huge amount of time they take to reheat (integrated heat pump type), can be around 8 hrs depending on capacity
But you can normally get a combi boiler to heat a cylinder without too much effort. Have a search, I did on my Atag, with a relay, 3 port valve and a resister. But if you go that route get a cylinder with a minimum 3m2 coil and then you can heat cylinder in full condensing mode for best efficiency.
