Change User ID after recreating account
So in playing around and setting up Emoncms on my own Ubuntu server, I loaded some sample data and ended up deciding to delete the one and only user and starting again.
So I recreated my user from the login screen and have just realised that I have no admin access. A forum search shows that the admin user must be user 1, however by deleting a user and starting from scratch, the system allocated me User ID 2 - hence no Admin access. And because I deleted User ID 1, I have no way of logging in that way.
So, short of starting from scratch with a new install (I really really don’t wanna do that) - is there any other way?
I’m thinking of access mysql via the command line and changing the User ID to 1 - will that break anything ? Or is there an ā€˜admin’ tag inside the mysql datase as well?
Any help appreciated .
Pete M
This has happened before. Did you try searching here?
Note - this relates to an old version of emonCMS - locations and names (i.e. settings.php) have changed, but I’m not familiar with the details.
Hi Robert,
Yes I’d done a search prior to posting. Those thread you linked don’t help out my particular issue.
Update: Problem solved.
I backed up the mysql database from using MYSQL at the command line, then updated UserID 2 from Admin = 0 to Admin =1
(UPDATE users SET admin=1 WHERE id=2;)
Logged out, logged back in. Admin functions are back.
Pete
