I have an emonESP with a firmware set to 9600 baud rate because I have the 3-phase sketch on my EmonTx. When I try to connect to the emonESP for the first time to start the config, the device keeps trying to connect to the emonESP_xxxx network with no success:
I’ve tried other devices, I re-flashed a lot of times with different tools. The server is starting as you can see below:
But when I flash the emonESP with a firmware set to 115200 baud rate this problem does not happen.
I don’t know what else I could do.
Thanks,
