Can't connect to emoncms local
I’m running an emonpi on latest software. Yesterday I went in locally and did an “update all”. All seemed to be working OK and has been logging to emoncms web just fine for the last 24h etc.
However, something else happened with the Wi-Fi today (another problem for later) and I tried connecting to the emonpi locally again.
Unfortunately I’ve come up with 2 errors which I don’t know the fix for.
First was:
Can’t connect to database, please verify credentials/configuration in settings.ini
Error message: Connection refused
I tried restarting the pi and now get the following error:
Fatal error: Uncaught Error: Call to undefined function set_emoncms_lang() in /var/www/emoncms/index.php:152 Stack trace: #0 {main} thrown in /var/www/emoncms/index.php on line 152
Even now it is still logging to emoncms web app just fine, but any advice on how to fix this?
I did read some bits about updating the settings.ini file - but to be honest I’ve not idea how to do that!
Henry
Hello @pearsonhenry2
How did you update the emonpi? Did you use the built in updater? Do you know how old the emonpi is otherwise, or the image version?
This is what the latest settings.ini should look like, you could try copying this in, it would be worth saving a backup of your current file:
emoncms_dir = "/opt/emoncms"
openenergymonitor_dir = "/opt/openenergymonitor"
[sql]
server = "127.0.0.1"
database = "emoncms"
username = "emoncms"
password = "emonpiemoncmsmysql2016"
; Skip database setup test - set to false once database has been setup.
dbtest   = true
[redis]
enabled = true
prefix = ''
[mqtt]
enabled = true
user = 'emonpi'
password = 'emonpimqtt2016'
[feed]
engines_hidden = [0,6,10]
redisbuffer[enabled] = true
redisbuffer[sleep] = 300
phpfina[datadir] = '/var/opt/emoncms/phpfina/'
phptimeseries[datadir] = '/var/opt/emoncms/phptimeseries/'
[interface]
enable_admin_ui = true
feedviewpath = "graph/"
favicon = "favicon_emonpi.png"
[log]
; Log Level: 1=INFO, 2=WARN, 3=ERROR
level = 2
@TrystanLea
I just used the built in updater through the web interface (just going to IP and logging in locally), just clicked “update all” and left it to run.
It was rebuilt in October time so is on July 20 image version.
To copy into the settings.ini do I need to physically remove the SD card from the emonpi and do it on a PC or is there a better way to do it?
The settings.ini file is on a linux ex4 filesystem so depending on what OS you are running on your PC it may not show up.
Using SSH may be the easiest following the guide here Service Credentials - Guide | OpenEnergyMonitor
Or I worry that there’s a larger problem underlying it, perhaps a card fault. It might be worth restoring onto a new card Import / Backup - Guide | OpenEnergyMonitor cant think why the errors would have otherwise happened on a July 20 image…
It was also a new card back in October when it go rebuilt, so hoping it isn’t a card fault!
I did read through the SSH guide earlier, I’m on Win10, all connected with Putty. I know some basic python but honestly no idea how to get that stuff above onto a pi.
Ok great, if your connected, could you try, copying the current contents of the settings file here? The steps are:
cd /var/www/emoncms
cat settings.ini
Might be worth checking if settings.php exists
ls -lh /var/www/emoncms/settings.php
Hopefully it will say:
ls: cannot access '/var/www/emoncms/settings.php': No such file or directory
If it does exist then you can try moving it
cd /var/www/emoncms
mv settings.php settings.php.backup
Then check if the local emoncms interface starts working
Trystan - all connected and check, settings.ini match above
[sql]
dbtest   = true
[redis]
enabled = true
prefix = ''
[mqtt]
enabled = true
user = 'emonpi'
[feed]
[interface]
[log]
level = 2
Settings.php does not exist
pi@emonpi:/var/www/emoncms $ ls -lh /var/www/emoncms/settings.php
Local emoncms still gives the same error
Fatal error : Uncaught Error: Call to undefined function set_emoncms_lang() in /var/www/emoncms/index.php:152 Stack trace: #0 {main} thrown in /var/www/emoncms/index.php on line 152
@TrystanLea Short of a total rebuild any other suggestions for a fix?
It’s all still feeding just fine through to emoncms.org but getting the same error for local login.
A rebuild wouldn’t be a disaster as it’s a pretty standard solar setup, but a bit of a pain.
@pearsonhenry2 thats strange could you print the output of the following here:
cd /var/www/emoncms
git status
@TrystanLea - my thoughts exactly! At least it means there’s no great rush, over Christmas, to get it fixed, but would be nice.
Output here:
pi@emonpi:~ $ cd /var/www/emoncms
pi@emonpi:/var/www/emoncms $ git status
On branch stable
Your branch is up to date with 'origin/stable'.
nothing to commit, working tree clean
Hmm, that all looks fine… could you copy the contents of /var/log/emoncms/emonpiupdate.log here?
You could also try running the updater again manually:
/opt/openenergymonitor/EmonScripts/update/service-runner-update.sh all emonpi
@TrystanLea I seems to get a permission denied error to read the log. Newbie to putty/ssh so I’m probably doing something wrong (logged in with pi/emonpi2016)
pi@emonpi:~ $ /var/log/emoncms/emonpiupdate.log
-bash: /var/log/emoncms/emonpiupdate.log: Permission denied
pi@emonpi:~ $
I also just did a manual update, seemed to run OK, but alas still get the same error when connecting directly through web browser.
Here’s the full update script in case it’s helpful
pi@emonpi:~ $ /opt/openenergymonitor/EmonScripts/update/service-runner-update.sh        all emonpi
Starting update via service-runner-update.sh (v3.0) >
- emonSD version: emonSD-24Jul20
- supported images: emonSD-24Jul20 emonSD-02Oct19 emonSD-17Oct19
- emonSD base image check passed...continue update
git pull /opt/openenergymonitor/EmonScripts
  master
* stable
On branch stable
Already up to date.
Main Update Script
Date: Mon 21 Dec 22:16:51 GMT 2020
EUID: 1000
openenergymonitor_dir: /opt/openenergymonitor
type: all
firmware: emonpi
Reading package lists... Done
Building dependency tree
Reading state information... Done
python3-pip is already the newest version (18.1-5+rpt1).
The following package was automatically installed and is no longer required:
  rpi-eeprom-images
Use 'sudo apt autoremove' to remove it.
0 upgraded, 0 newly installed, 0 to remove and 75 not upgraded.
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: redis in /home/pi/.local/lib/python3.7/site-packages (3.5.3)
Hardware detected: EmonPi
Stopping emonPiLCD service
Display update message on LCD
Running apt-get update
Hit:1 http://archive.raspberrypi.org/debian buster InRelease
Get:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
Err:1 http://archive.raspberrypi.org/debian buster InRelease
  Splitting up /var/lib/apt/lists/archive.raspberrypi.org_debian_dists_buster_InRelease into data and signature failed
Get:3 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13.0 MB]
Hit:4 http://raspbian.raspberrypi.org/raspbian buster/contrib armhf Packages
Hit:5 http://raspbian.raspberrypi.org/raspbian buster/non-free armhf Packages
Hit:6 http://raspbian.raspberrypi.org/raspbian buster/rpi armhf Packages
Ign:4 http://raspbian.raspberrypi.org/raspbian buster/contrib armhf Packages
Ign:5 http://raspbian.raspberrypi.org/raspbian buster/non-free armhf Packages
Ign:6 http://raspbian.raspberrypi.org/raspbian buster/rpi armhf Packages
Fetched 13.0 MB in 21s (618 kB/s)
Reading package lists... Error!
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://archive.raspberrypi.org/debian buster InRelease: Splitting up /var/lib/apt/lists/archive.raspberrypi.org_debian_dists_buster_InRelease into data and signature failed
W: Failed to fetch http://archive.raspberrypi.org/debian/dists/buster/InRelease  Splitting up /var/lib/apt/lists/archive.raspberrypi.org_debian_dists_buster_InRelease into data and signature failed
W: Some index files failed to download. They have been ignored, or old ones used instead.
E: Splitting of clearsigned file /var/lib/apt/lists/archive.raspberrypi.org_debian_dists_buster_InRelease failed as it doesn't contain all expected parts
E: The package lists or status file could not be parsed or opened.
git pull /opt/openenergymonitor/emonpi
* master
On branch master
Your branch is up to date with 'origin/master'.
Fetching origin
Already up to date.
git pull /opt/openenergymonitor/RFM2Pi
* master
On branch master
Fetching origin
Already up to date.
Start emonhub update script:
emonHub update
git fetch --all --prune -v
Fetching origin
From https://github.com/openenergymonitor/emonhub
 = [up to date]      stable                   -> origin/stable
 = [up to date]      MQTTSubscriberInterfacer -> origin/MQTTSubscriberInterfacer
 = [up to date]      emon-pi                  -> origin/emon-pi
 = [up to date]      env_example              -> origin/env_example
 = [up to date]      include_serial_number    -> origin/include_serial_number
 = [up to date]      lanip-status             -> origin/lanip-status
 = [up to date]      master                   -> origin/master
 = [up to date]      redis_config_interface   -> origin/redis_config_interface
 = [up to date]      unitless_decoder         -> origin/unitless_decoder
git status
On branch stable
Untracked files:
  (use "git add <file>..." to include in what will be committed)
        src/src
nothing added to commit but untracked files present (use "git add" to track)
git pull origin stable
 * branch            stable     -> FETCH_HEAD
Already up to date.
Running emonhub install & update script emonSD_pi_env:1
Requirement already satisfied: paho-mqtt in /usr/local/lib/python3.7/dist-packages (1.5.0)
Requirement already satisfied: requests in /usr/lib/python3/dist-packages (2.21.0)
Requirement already satisfied: pybluez in /usr/local/lib/python3.7/dist-packages (0.23)
Requirement already satisfied: py-sds011 in /usr/local/lib/python3.7/dist-packages (0.9)
Requirement already satisfied: sdm_modbus in /usr/local/lib/python3.7/dist-packages (0.4.4)
Requirement already satisfied: pyserial in /usr/lib/python3/dist-packages (from py-sds011) (3.4)
Requirement already satisfied: pymodbus>=2.3.0 in /usr/local/lib/python3.7/dist-packages (from sdm_modbus) (2.4.0)
Requirement already satisfied: six>=1.15.0 in /usr/local/lib/python3.7/dist-packages (from pymodbus>=2.3.0->sdm_modbus) (1.15.0)
Requirement already satisfied: RPi.GPIO in /usr/lib/python3/dist-packages (0.7.0)
The user `emonhub' is already a member of `gpio'.
Unit /etc/systemd/system/[email protected] is masked, ignoring.
useradd: user 'emonhub' already exists
- installing emonhub.service
- Service ActiveState=active
Running emonhub automatic node addition script
[[5]]
Node 5 already present
[[6]]
Node 6 already present
[[7]]
Node 7 already present
[[8]]
Node 8 already present
[[9]]
Node 9 already present
[[10]]
Node 10 already present
[[11]]
Node 11 already present
[[12]]
Node 12 already present
[[13]]
Node 13 already present
[[14]]
Node 14 already present
[[15]]
Node 15 already present
[[16]]
Node 16 already present
[[19]]
Node 19 already present
[[20]]
Node 20 already present
[[21]]
Node 21 already present
[[22]]
Node 22 already present
[[23]]
Node 23 already present
[[24]]
Node 24 already present
[[25]]
Node 25 already present
[[26]]
Node 26 already present
Start emoncms update:
Update Emoncms Core
Checking status of /var/www/emoncms git repository
- git branch: stable
- no local changes
- running: git pull origin stable
Fetching origin
From https://github.com/emoncms/emoncms
Already up to date.
Update Emoncms database
Update Emoncms Services
emoncms_mqtt.service already installed
feedwriter.service already installed
service-runner.service already installed
Reloading systemctl deamon
Restarting Services...
- sudo systemctl restart feedwriter.service
--- ActiveState=active ---
- sudo systemctl restart emoncms_mqtt.service
- sudo systemctl restart emonhub.service
/opt/openenergymonitor/EmonScripts/sudoers.d/emoncms-rebootbutton: parsed OK
emonPi emoncms admin reboot button sudoers updated
Update Emoncms Modules
Updating /var/www/emoncms/Modules/app module
- git tags: 2.2.2-2-gd345c22
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/config module
- git tags: 2.0.5-6-gd28ff1e
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/dashboard module
- git tags: 2.0.8-9-gdc07d12
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/device module
- git tags: 2.0.7
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/graph module
- git tags: 2.0.9-3-g6c18b0c
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/setup module
fatal: No names found, cannot describe anything.
- git tags:
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/wifi module
- git tags: 2.0.3
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
/opt/openenergymonitor/EmonScripts/sudoers.d/wifi-sudoers: parsed OK
wifi sudoers entry updated
Updating /opt/emoncms/modules/backup module
- git tags: 2.2.6
- no local changes
Already up to date.
Already on 'stable'
Updating /opt/emoncms/modules/demandshaper module
- git tags: 2.1.2
- no local changes
Already up to date.
Already on 'stable'
Updating /opt/emoncms/modules/postprocess module
- git tags: 2.1.4
- no local changes
Already up to date.
Already on 'stable'
Updating /opt/emoncms/modules/sync module
- git tags: 2.0.5-3-g109816f
- no local changes
Already up to date.
Already on 'stable'
Updating /opt/emoncms/modules/usefulscripts module
- git tags:
- no local changes
Already up to date.
Already on 'stable'
Backup module installation and update script
- Loading EmonScripts config.ini
- Copying default.config.cfg to config.cfg
- Setting config.cfg settings
- Backup module symlink already exists
- PHP Version: 7.3
- Creating /etc/php/7.3/mods-available/emoncmsbackup.ini
post_max_size = 3G
upload_max_filesize = 3G
upload_tmp_dir = /var/opt/emoncms/backup/uploads
- phpenmod emoncmsbackup
- /var/opt/emoncms/backup already exists
- /var/opt/emoncms/backup/uploads already exists
- restarting apache
EmonPi LCD Update
Requirement already satisfied: xmltodict in /home/pi/.local/lib/python3.7/site-packages (0.12.0)
- reinstalling emonPiLCD.service
Removed /etc/systemd/system/emonPiLCD.service.
Removed /etc/systemd/system/multi-user.target.wants/emonPiLCD.service.
- installing emonPiLCD.service
Created symlink /etc/systemd/system/multi-user.target.wants/emonPiLCD.service → /opt/openenergymonitor/emonpi/lcd/emonPiLCD.service.
Created symlink /etc/systemd/system/emonPiLCD.service → /opt/openenergymonitor/emonpi/lcd/emonPiLCD.service.
EmonPi Firmware Update (Discrete Sampling)
Start ATmega328 serial upload using avrdude with latest.hex
Attempt: 1
avrdude -c arduino -p ATMEGA328P -P /dev/ttyAMA0 -b 115200 -U flash:w:/opt/openenergymonitor/emonpi/firmware/compiled/latest.hex
Note: progress written to logfile /var/log/emoncms/firmware.log
avrdude-original: Using autoreset DTR on GPIO Pin 7
strace: |autoreset: Broken pipe
avrdude-original: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude-original: Device signature = 0x1e950f (probably m328p)
avrdude-original: NOTE: "flash" memory has been specified, an erase cycle will be performed
                  To disable this feature, specify the -D option.
avrdude-original: erasing chip
avrdude-original: reading input file "/opt/openenergymonitor/emonpi/firmware/compiled/latest.hex"
avrdude-original: input file /opt/openenergymonitor/emonpi/firmware/compiled/latest.hex auto detected as Intel Hex
avrdude-original: writing flash (18526 bytes):
Writing | ################################################## | 100% 2.63s
avrdude-original: 18526 bytes of flash written
avrdude-original: verifying flash memory against /opt/openenergymonitor/emonpi/firmware/compiled/latest.hex:
avrdude-original: load data flash data from input file /opt/openenergymonitor/emonpi/firmware/compiled/latest.hex:
avrdude-original: input file /opt/openenergymonitor/emonpi/firmware/compiled/latest.hex contains 18526 bytes
avrdude-original: reading on-chip flash data:
Reading | ################################################## | 100% 1.99s
avrdude-original: verifying ...
avrdude-original: 18526 bytes of flash verified
avrdude-original: safemode: Fuses OK (E:00, H:00, L:00)
avrdude-original done.  Thank you.
SUCCESS: flash verifed
waiting for emonpi to stop controlling LCD
Starting emonPi LCD service..
emonPi update done: Mon 21 Dec 22:20:22 GMT 2020
restarting service-runner
Thanks @pearsonhenry2 there are some package list errors in there, but otherwise the emoncms update goes fine, so Im still not sure what’s causing the issue.
What is strange is that the set_emoncms_lang function that it cant find, is … or should be in /var/www/emoncms/locale.php (towards the bottom emoncms/locale.php at master · emoncms/emoncms · GitHub) which is always loaded by the index.php script (towards the top emoncms/index.php at master · emoncms/emoncms · GitHub). Git is saying that you dont have any local changes and its all up to date so I cant quite make sense of that.
It may be that there is some filesystem corruption that is causing locale.php to only partially load perhaps…
I think it would be best to burn the latest image again to a new SD card. If your only using it to post data to emoncms.org, you could just enter the emonhub config on the new image rather than using the import tool.
Sorry about this hassle
@TrystanLea Thank you.
Got a new 16GN microSD on order for tomorrow, will give a new install a go.
From last time a new install is actually pretty quick - the longest part is getting the pi casing open and closed again!
Is the card full?
@borpin
Is there an easy way to check, (perhaps via SSH) to see if the card is full?
Yes :slight_smile:
df -h
Thanks!
I don’t think it is full:
pi@emonpi:~ $ df -h
Filesystem      Size  Used Avail Use% Mounted on
/dev/root       4.1G  2.0G  2.0G  51% /
devtmpfs        431M     0  431M   0% /dev
tmpfs           463M     0  463M   0% /dev/shm
tmpfs           463M   18M  446M   4% /run
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           463M     0  463M   0% /sys/fs/cgroup
tmpfs           1.0M     0  1.0M   0% /var/lib/php/sessions
tmpfs            30M     0   30M   0% /tmp
tmpfs           1.0M     0  1.0M   0% /var/tmp
/dev/mmcblk0p3  9.9G   17M  9.4G   1% /var/opt/emoncms
/dev/mmcblk0p1  253M   54M  199M  22% /boot
log2ram          50M   11M   40M  21% /var/log
tmpfs            93M     0   93M   0% /run/user/1000
pi@emonpi:~ $
Will rebuild at some point in the next few days.
What does running
sudo apt-get update
from the command line do? Do you still see the errors?
Google the error you do see.
[edit]
The most common solution is to remove the lists. I have seen 2 different removal suggestions;
  1. Remove the file sources.list
    sudo rm -fr /etc/apt/sources.list
    and
    sudo rm /var/lib/apt/lists/*
  2. Run the update process. It will create the file again
    sudo apt-get update
