I am experiencing the same ERROR: Could not save processlist. undefined disappear issue. I created a simple nodered flow that publishes gallons to emon/water/gallons. I can see the data on the Input View page:
Only last screenshot is readable, the 2 others can’t be zoomed in and for me it is impossible to read the error message for exemple.
I guess this is local install, is the SD card not near full by any chance ? Reboot often cleans out many cached files and gives some extra space but problems will arise soon enough if it is this case.
Hey Eric! I updated the above images. (I shrunk them too much trying to save OEM server space!)
Yes, local install on an emonPi and using an 8 GB SD card. The SD card isn’t full but it is getting there in the “root” area. And there are no obvious errors in any of the logs (i.e., emonhub, emoncms, syslog).
I didn’t want to reboot until I exhausted all troubleshooting opportunities for @glyn.hudson or @TrystanLea. I am fairly sure that a reboot will fix the issues but just temporarily.
