I raised a PR on GitHub quite some time ago about the paths in the backup module being hard coded (not even a variable to set in the script) which is a real PITA. IIRC, to use the backup module from EmonCMS you need the feedrunner(?) script but I didn’t understand why at the time.
Do you have redis enabled?
