Can I ask what cable gland is used for the RJ11 cable on the emonVs-PSU?
Does the same one work when a USB cable is fed through with the RJ11 cable?
Thanks!
Brandon
Thanks!
Brandon
@Gwil would be the one to answer this.
However, the gland on the low-voltage end is a “standard” one for a round cable and does not anchor the flat cable that’s used for the d.c. power and the voltage samples. It would require a special bush (similar to this but noting the cable used is a lot flatter than 1 mm² TE) to provide a secure mechanical fixing, which I would expect to be prohibitively expensive.
@glyn.hudson - do you have the part number for the gland we use? Also, look at Robert’s comment above.
It is an M20, I believe it is this one:
https://cpc.farnell.com/pro-power/mg-20-black/m20-cable-gland-black/dp/CBBR7376
Yes, it’s just a standard M20 gland
