The ESP32 will give us more resources to enable future developments. Currently, the ESP32 version has a stable point of development and is feature parity with the WiFi 2.x ESP8266 version. With the following new features:
HTTPS Emoncms posting support
MQTT device discovery (announce message on connection)
Unique hostname & device ID (enable multiple OpenEVSE on same WiFi)
VPN / port forward access fixed
ESP32 hardware is now available if you wish to get onboard with ESP32 WiFi 3.x, it’s s drop-in plug-and-play replacement with the ESP8266 module:
Hi glyn i understand that by upgrading to the esp 32 solves the problem of no comunication via VPN on the older esp …
i was trying to find the binary file to download to the esp32 are they avalable yet .
othrwise i would like to compile this code to try it . i use the aurdino ide am i able to use this
or do i need to set up a compleat new system to be able to compile this ?
regards bill
Many thanks I have spent the afternoon trying to find this .
I have started trying setup platformio on a Ubuntu on a pi laptop But that seems to be giving me a few issues . Think I may set up
A new install on a laptop I have spare thinking of Linux mint install
We’re still currently shipping ESP8266 with WiFi 2.x in current EmonEVSE / OpenEVSE kits purchased via the shop.
The ESP32 WiFi 3.x is still in beta testing and is not yet being included as standard. This post to announce the availability of ESP32 pre-loaded with WiFi 3.x in the shop is for developers and early adopters to help us test before we make the switch.
Yep, I realise that, but the shop listing for the ESP32 you gave above says that it still includes the ESP8266.
Includes
Huzzah ESP8266 WiFi Module
UBEC 5v Regulated power module
Custom power & communications cable
Latest OpenEVSE WiFi V3 code preloaded
Speaking of which, I assume you don’t actually need to swap out the power module, or the comms cable?
What I was querying was that if I buy the ESP32 module now, it’s not going to change down the road. It’s not a custom module that you could be making modifications to?
hi glyn been a few days befor i could get to this .
i have uploaded the bin file to the esp32 and have tried several upload speed but when i power it back up i get the same error
rst:0x10 (RTCWDT_RTC_RESET),boot (SPI_FAST_FLASH_BOOT)
flash read err , 1000
ets_main.c 371
ets Jun 8 2016 00:22:57
it looks like i am missing something that i have not done
I am using NodeMCU PyFlasher to upload file it compleats and reports successfull
any idears or should i use a diferant programer
thanks bill
hi glyn
sorted it followed your instrution on my linus laptop and this all worked compiled and uploaded to boards
will try fitting them tomorrow then hope full all will be good
Hi Glyn I have managed to change these boards onto my two chargers and they are now allowing me to come in via a Rpi Vpn = Win
only thing is i am finding the boards will run for several hours but then loose conection to the network … when this happens if i scan for wifi networks i find ESP_9D6015 this will let me conect to it with the adress of 192.168.4.1 but does not give any webpage .
I am using the " vroom esp 32" node module . i have programed both using linux and platform io i have also uploaded the binary file you pointed me too . as a network upload .
to see if that sttoped the loss of conection/ crash to one of them they are both on V3.0.3.dev and the Evse is 5.1.0.EU … Initialy i also had a problem with demandshaper not responding to them but i seemed to have sorted this by doing a reboot of the emonpi and now demand shaper comunicates with the esp32 boards …
is there a way i can compile to allow me to monitor debug via the usb port so i can log to laptop see if this will give any indication as to why they keep droping out ?
thanks for your time regards Bill Burgess
thanks for info
Ok I will try to set this up on the bench at present I have removed from chargers and gone back to the older esp . As charges in use daily
I can confirm that while working I could VPN into them every time untill they dropped out of WiFi
Next few days I will set up on the bench I have programmed a nano up with the ev code so I hope I can connect them to this and at least it should report lots of faults back. … but at least put it in a working environment to test
No problem connecting to my ESP32 web interface via VPN - so I can confirm that problem is fixed. I am also seeing the intermittent loss of connectivity to the web config page, as I have reported elsewhere.
I’ve just posted a firmware update to the ESP32 which contains a significant update to the Solar PV divert function. If any of you ESP32 beta users have solar PV and are able to test this would be much appreciated:
It’s working well here.
Apart from the opencms connection always showing ‘Connected: No’
I’m unsure about the Tesla integration.
Some parts obviously have been done but, for example, ‘savetesla’ comes back with ‘not found’. Should this be in 3.2?
What is the mechanism used? If it is polling, I’m unlikely to use it anyway…
The Tesla integration does not poll or wake up the vehicle, it just gets the last values from the server. This works fine since when the car is charging the Soc will be updated regularly on the server. We plan to add a Tesla SoC display in the interface and charge limit based on %.
