Hi Everyone,
I’m in the process of setting up a solar PV system with battery storage and want to integrate OpenEnergyMonitor for real-time monitoring and data analysis. I’ve read through some of the guides and forum discussions, but I still have a few questions before finalizing my setup.
My System Setup:
- Solar PV: 5kW
- Battery Storage: 10kWh
- Inverter: Hybrid inverter with grid-tie capability
- Energy Consumption: A mix of home appliances and EV charging
My Goals:
- Monitor solar generation, battery charge/discharge cycles, and household consumption
- Track grid import/export to optimize self-consumption
- Set up alerts for battery state-of-charge and system efficiency
- Ideally, integrate data into Home Assistant for automation
Questions:
- Hardware Recommendation: Would an EmonPi or EmonTx be the better choice for my needs? Do I need additional CT clamps or other sensors?
- Battery Monitoring: Since my battery is connected via the hybrid inverter, what’s the best way to get accurate charge/discharge readings? Any recommended workarounds if direct monitoring isn’t possible?
- Grid Export Tracking: How precise is the standard setup in detecting grid import/export fluctuations? Any tips on calibration?
- Home Assistant Integration: Has anyone successfully pulled OpenEnergyMonitor data into Home Assistant? If so, what’s the best way to do it?
- General Best Practices: Any advice on data logging, MQTT usage, or visualization tools for long-term analysis?
I appreciate any insights or shared experiences from those who have a similar setup. Looking forward to your recommendations!
I also checked this: https://community.openenergymonitor.org/t/integrating-pv-and-battery-monitoring-systems/power-apps
Thanks in advance!
