Thanks all of you for this great open hardware-source Project.
I have made a little project to see my modified sine wave invertir’s wave form.
I have solder all components as emonTx’s schema (only one ammeter input). But I have found a strange error in my hardware.
The schema shows a 1K resistor and a 3.3V zener diode for the input of each analog value.
I have been getting crazy because, with any load, I could only get 1.43 Vdc in that pin, instead 1.66Vdc (more less)
I have found, after doing a lot of change in components and getting crazy, that if I disconnect ZENER diodes, I get 1.66Vdc and get it working.
With ZENER diodes connected, I get 1.43Vdc and the wave of an AC-AC adapter goes above 0Vdc. Without them, I can see perfect my AC-AC wave.
The way I have solder the zener diodes is::
zener’s side with the line mark to the “end” of 1K resistor. That point is also connected with the analog input of my arduino uno board.
zener’s other side to ground.
1K
---------////----------------> to analog input
/______
__
_
I have already changed one of them. Same result. I bought them one year ago to china (ebay).
May be they are defecctive ? The circuit is ok, as without zener, I can get a perfect sin wave between 100 and 900 (range for arduino 0-1023) analog values. I have powered it with 3.3V (it is a arduino buono, with both 3.3V or 5V power options; grounds connected, power rail from arduino 3.3V; (I have also tried power the emonTx hardware directly with AC-AC adaptor, same result: with zeners, bad, without them, perfect), …
I know I could change them with a BAT54S or similar. But for me, a newbie, the zener diode is very simple, but I don’t know what I am doing wrong.
Regards,
