Those are messages where the checksum is incorrect. Probably, it is trying to understand 4G. Now that the receiver is working at 433 MHz, those signals are not received.
If you do not want to send data to emoncms.org, then in emonhub.conf, in the [interfacers] part, [[emoncmsorg]], change: senddata = 0 # Enable sending data to Emoncms.org
The OEM Shop now only sells 433 MHz as standard. If you think you might move house again and go back to using 868 MHz, you should buy 868 MHz. You can buy units without the RF module so that you can fit your own 868 MHz module if you decide to remain with 868 MHz.
If you are not likely to go back to 868 MHz, your new unit will transmit better at 433 MHz if it is a 433 MHz one. You might damage a RFM69CW module if you use it at full power on the wrong frequency.
I do not recommend that you try to change the RFM12B / RFM69CW modules on your old emonTx and emonTH. To do that without damage, you need the correct professional de-soldering equipment.
The application notes for the RFM69CW used to warn that the transmitter output stage might be damaged if the transmitter is operated at or near maximum power without a correctly matched antenna. That would include operating at 433 MHz with a 868 MHz antenna, or vice versa.
This does not apply (as far as I know) to the RFM12B, which is a lower-power transmitter. Link to identify your radio module.
Is there any possibility your kit is 433MHz and not 868 as you recall?
If ALL you did was change the setting in emonhub.conf from 868 to 433 without uploading new “433” firmware to the emonTx and emonTH, then the receiver would be listening on 433MHz whilst the nodes were still transmitting on 868MHz and you would receive no data.
Alternatively if you have uploaded new “433” firmware’s and also changed the emonhub setting so all your devices are 868 hardware, reconfigured to use 433, then that’s pretty impressive that they work when both ends are running incorrect frequencies, normally configuring a device to run at the wrong frequency is to match another device(s) so only one tends to be “wrong” rather than both the transmitter and receiver.
Can you confirm the frequencies of the hardware as well when you identify the module as Robert suggests?
I’m not entirely sure where that setting has come from.
If you do not want the facility to send to emoncms.org the correct thing to do is to comment out either the whole [[emoncmsorg]] block of settings from the conf (more intuitive) or just comment out the type = line so that the interfacer instance doesn’t exist (shortcut - just one hash does the trick). All that setting appears to do is not send the data it collates and holds in memory, to emoncms, a sort of “pause sending” rather than disabling the redundant interfacer.
The original emonhub code had pause input and pause output functionality for every interfacer inbuilt, I think that got stripped away with the emonpi variant of emonhub as it wasn’t wanted, strange it was partially reintroduced under a different name…
Thanks for clarifying that, Paul. It came from emonhub.conf (RPi version) so in the absence of full and explicit documentation, I took it to do what it said “on the tin”. I’ve put your explanation in my personal FAQ file.
Note: the RFM modules do appear to work on a harmonic (i.e. the ends at different frequencies), but the range is extremely limited, 10 - 20 cm. I’m not sure which way round they work. They certainly work better when both ends are at the same frequency, even when that is not correct for the hardware.
Exactly, the fact that’s what he had prior to changing the setting in emonhub.conf and all is great since changing it, might suggest he was trying to run a 433 at 868 to start with and now he’s running 433 at 433, the range is as expected rather than performing spectacularly for what was believed to be deliberately ill-configured devices.
But the first line of Nomad’s first post says he has all 868 MHz hardware. I was believing that, especially as it was bought a few years ago - presumably before the shop dropped the 868 MHz range. As you say, it seems that it might have been a mix of frequencies all the time.
Since 868 MHz is very close to the second harmonic of 433 MHz, the 433 device will perform MUCH better at 868 MHz, than an 868 MHz device forced to work at 433 MHz. (No harmonic relationship in that scenario)
If memory serves, the specific frequency the 433 radio operates at is 433.92 MHz,
which yields a 2nd harmonic of 867.84 MHz.
I’m quite sure to order 868Mhz, I have to check my bill for that.
But till I had trouble with one node in my first setup several years ago cause by several interferances, I remenber to have check carrefuly my hardware.
That time it came from electric cable and washing maching with induction motor.
All my antena are the same… long one and white.
The thing that point to what Paul says is maybe my RaspberryPi Module is a 433Mhz with a 868Mhz antena or something like that because under the 433Mhz case is check.
Please do that. The RFM12Pi can have either the 433 MHz or the 868 MHz radio fitted. The picture shows a 868 MHz version. The wire antenna is 165 mm long for 433 MHz or 82 mm long for 868 MHz.
Look carefully at your RFM module, and look for the capacitor marked with an arrow in the pictures here. That is how you know the frequency of the RFM itself.
sorry for the very long time before my answer.
So in fact you are right I’m in full 433Mhz
I just load a bad old config that came from my first setup…
The thing that confuse me is a real marking error that show I have a 866Mhz but it’s a 433…
I find an old mail discution I have with Aled in december 2013.
> On the print invoices inside the box, you write by hand that the Bundle
> is a 433Mhz as expected …
> But under the emonTX, the case 868 Mhz is check
