You can force it in software to run at 433Mhx by setting frequency in emonhub.conf or issuing 4b serial command manully. Range will be reduced significantly since the antenna system is optimised for 868Mhz. I’m not sure if it’s possible to change the hardware without chaning the module.
I’m reasonably certain that it’s not just that one capacitor that’s different, so it is necessary to change the module. (There are posts about this in the old forum.)
It’s worth trying the software method, I have several modules I have ‘forced’ to work at a differant frequency working fine in my (small) house. Just depends on the range you require.
I’m sure you will be able to sell the 868Mhz unit if you post it up in the ‘For Sale’ section of the forum. The 868 unit will be in high demand since we have stopped producing 868 to standardise on 433.
Christian, I’ll swop it for a 433Mhz RFM12pi if you’re interested?
I’ve got a brand new 433Mhz RFM12Pi sat in my workshop, and my emon system is 868Mhz.
