I want to monitor 6 channels currently, with possible expansion to 12 channels later
I use the SCT013-000 clamps
I tried with an ATMega328 with 6 sensors, but the readings are not accurate if it’s fast, when the sample time is long enough to read accurate readings (As compared to a commercial CT ammeter), I get one cycle every 30 seconds
My options are:
Use multiple ATMega328 with 2-3 clamps attached to each.
If you don’t mind a two week delivery time, a Due clone can be purchased for quite a bit less than the genuine article. I bought one for USD 17 and have had no issues wit it.
Here’s an example.
Yes and no, long story short, the South African Post Office is terrible, ebay orders take anywhere from 10 weeks up to a lifetime to deliver, so buying from ebay is only viable if DHL or similar is used, and then it’s cheaper to actually buy locally.
IotaWatt does look like exactly what I need, have thought of maybe using an ESP-12E since I have two or three of them laying around and I would’ve probably used an ESP to transmit the data either way.
