I just installed solar panels hooked up to APSystems micro inverters. Those micro-inverters communicate with APSystems ÉCU unit which can be used to monitor production and other parameters.
I am looking for a solution to grab the zigbee signal emitted by the micro-inverters and to feed it into my émondage… any suggestion on how to get started?
A search didn’t yield much, aside from the zigbee2mqtt plugin which seems to work the other way around to control zigbee devices from Matt.
I thought it was bi directional. Fairly sure it picks up status from paired devices (if they send it).
[edit]
I see there is a discourse and forum so I’d ask there http://www.zigbee2mqtt.io. Once published as an mqtt topic, importing the data should be simple.
zigbee2mqtt works in bidirectionally you can control a device as well as get info from a device… to get the most from it flash the usb zigbee sniffer with the newest z-stack firmware…
I found this to be the easiest step by step method
but just using the the newest z-stack firmware listed above.
once you get working you could then submit it to zigbee2mqtt forum to get it add to the list of supported devices
Thanks for the answers, the “sniffers” was the piece I had missed.
Between hacking my emonbase without breaking updates, getting the zigbee hardware/software stack working, and working out the proprietary APSystems zigbee format this looks like a pretty involved endeavor, so I’ll probably take some time to research alternatives.
For example using node-red to scrape the APSystems ECU web application
I’m not a fan of loading everything on one RPi - too much to break. I have a PiZeroW setup just for my zigbee gateway. It has just sat there and done it’s job no bother.
actually to get itt (the zigbee bridge) to work is not that difficult - while never did on RPi which is well supported I did mine on openwrt router platform so I had to jump an extra mile to get it to work… but setting up new devices are actually not that difficult - generally just a little trial and error- copy and paste for the most part
It will likely depend exactly which model of ECU you have. It sounds new so could be the ECU-R. If you ever find a web interface on the model to post how you get to it! As far as I can see that web interface trick was only available on the ECU-3.
The times are Unix epoch timestamps, I call the URL every 5mn (that’s the rate at which the ECU-C updates) and I grab the last entry in the power array. That in a node-red process, so I just post to MQTT and emoncms takes over from there
Franck102, do you think is possible to connect to APSystems YC600 without ECU-3. I use zigbee2mqtt. I see xaiomi devices but i don`t see inverter. Power off/on inverter - nothing happens in zigbee network - log show only xiaomi devices. The device AP YC600 has no button - I can not restart. I can only turn it on and off but it does not give. The device works - it produces energy.
Best regards,
Przemek
I never followed up on that idea, because I managed to get the info I need from the ECU-C over WiFi… and since I have never looked into Zigbee, I won’t be able to help you much.
We have managed to sniff the YC600 initial traffic. We are looking for someone who owns an ECU-R (ECU-C might also be good enough) and is willing to sniff the registration traffic of a new device. Please join our discussion: pairing APsystem YC600 · Issue #4221 · Koenkk/zigbee2mqtt · GitHub
