Hi Paul,
I’ve added the phptimeseries debug to the processing, a very good idea I’d not thought of! I’ll get some more screen grabs early tomorrow morning.
I’ve gone over all the processing (there is rather a lot of it) and the only place writing to the Node10:Power is the second from top line here, the rest is the bulk of the processing from the EmonTX.
This is the solar processing…
And this is the EV charger…
I can’t explain the 7:26.05 blip (below) either, but there is a clear correlation at 7:26.55 with the start of PV generation, on the graph and the new frame coming in at 7:27.01 on the log (more below).
> 2017-11-02 07:26:50,113 DEBUG RFM12Pi 71804 NEW FRAME : OK 10 165 0 0 0 0 0 61 97 (-75)
> 2017-11-02 07:26:50,116 DEBUG RFM12Pi 71804 Timestamp : 1509607610.11
> 2017-11-02 07:26:50,117 DEBUG RFM12Pi 71804 From Node : 10
> 2017-11-02 07:26:50,118 DEBUG RFM12Pi 71804 Values : [165, 0, 0, 24893]
> 2017-11-02 07:26:50,119 DEBUG RFM12Pi 71804 RSSI : -75
> 2017-11-02 07:26:50,120 DEBUG RFM12Pi 71804 Sent to channel(start)' : ToEmonCMS
> 2017-11-02 07:26:50,121 INFO RFM12Pi Publishing: emon/emontx/power1 165
> 2017-11-02 07:26:50,124 INFO RFM12Pi Publishing: emon/emontx/power2 0
> 2017-11-02 07:26:50,127 INFO RFM12Pi Publishing: emon/emontx/power3 0
> 2017-11-02 07:26:50,129 INFO RFM12Pi Publishing: emon/emontx/vrms 24893
> 2017-11-02 07:26:50,132 INFO RFM12Pi Publishing: emon/emontx/rssi -75
> 2017-11-02 07:26:50,134 INFO RFM12Pi Publishing: emonhub/rx/10/values 165,0,0,24893
> 2017-11-02 07:26:50,137 INFO RFM12Pi Publishing: emonhub/rx/10/rssi -75
> 2017-11-02 07:26:50,140 DEBUG RFM12Pi 71804 adding frame to buffer => [1509607610.112931, 10, 165, 0, 0, 24893, -75]
> 2017-11-02 07:26:50,141 DEBUG RFM12Pi 71804 adding frame to buffer => [1509607610.112931, 10, 165, 0, 0, 24893, -75]
> 2017-11-02 07:26:50,142 DEBUG RFM12Pi 71804 Sent to channel(end)' : ToEmonCMS
> 2017-11-02 07:26:55,823 DEBUG RFM12Pi 71805 NEW FRAME : OK 10 112 0 0 0 0 0 74 97 (-77)
> 2017-11-02 07:26:55,826 DEBUG RFM12Pi 71805 Timestamp : 1509607615.82
> 2017-11-02 07:26:55,828 DEBUG RFM12Pi 71805 From Node : 10
> 2017-11-02 07:26:55,830 DEBUG RFM12Pi 71805 Values : [112, 0, 0, 24906]
> 2017-11-02 07:26:55,832 DEBUG RFM12Pi 71805 RSSI : -77
> 2017-11-02 07:26:55,834 DEBUG RFM12Pi 71805 Sent to channel(start)' : ToEmonCMS
> 2017-11-02 07:26:55,836 INFO RFM12Pi Publishing: emon/emontx/power1 112
> 2017-11-02 07:26:55,839 INFO RFM12Pi Publishing: emon/emontx/power2 0
> 2017-11-02 07:26:55,842 INFO RFM12Pi Publishing: emon/emontx/power3 0
> 2017-11-02 07:26:55,845 INFO RFM12Pi Publishing: emon/emontx/vrms 24906
> 2017-11-02 07:26:55,847 INFO RFM12Pi Publishing: emon/emontx/rssi -77
> 2017-11-02 07:26:55,849 INFO RFM12Pi Publishing: emonhub/rx/10/values 112,0,0,24906
> 2017-11-02 07:26:55,851 INFO RFM12Pi Publishing: emonhub/rx/10/rssi -77
> 2017-11-02 07:26:55,854 DEBUG RFM12Pi 71805 adding frame to buffer => [1509607615.823166, 10, 112, 0, 0, 24906, -77]
> 2017-11-02 07:26:55,855 DEBUG RFM12Pi 71805 adding frame to buffer => [1509607615.823166, 10, 112, 0, 0, 24906, -77]
> 2017-11-02 07:26:55,856 DEBUG RFM12Pi 71805 Sent to channel(end)' : ToEmonCMS
> <snip>
> 2017-11-02 07:26:57,362 INFO emoncmsorg sending: https://emoncms.org/input/bulk.json?apikey=E-M-O-N-C-M-S-A-P-I-K-E-Y&data=[[1509607610.112931,10,165,0,0,24893,-75],[1509607615.823166,10,112,0,0,24906,-77],[1509607616.163777,22,1860,1880,6790,7500,3717,7144,-73]]&sentat=1509607617
> 2017-11-02 07:26:57,493 DEBUG emoncmsorg acknowledged receipt with 'ok' from https://emoncms.org
> 2017-11-02 07:26:57,494 INFO emoncmsorg sending: https://emoncms.org/myip/set.json?apikey=E-M-O-N-C-M-S-A-P-I-K-E-Y
> <snip>
> 2017-11-02 07:27:01,600 DEBUG RFM12Pi 71807 NEW FRAME : OK 10 115 0 16 0 0 0 74 97 (-77)
> 2017-11-02 07:27:01,603 DEBUG RFM12Pi 71807 Timestamp : 1509607621.6
> 2017-11-02 07:27:01,604 DEBUG RFM12Pi 71807 From Node : 10
> 2017-11-02 07:27:01,605 DEBUG RFM12Pi 71807 Values : [115, 16, 0, 24906]
> 2017-11-02 07:27:01,606 DEBUG RFM12Pi 71807 RSSI : -77
> 2017-11-02 07:27:01,607 DEBUG RFM12Pi 71807 Sent to channel(start)' : ToEmonCMS
> 2017-11-02 07:27:01,608 INFO RFM12Pi Publishing: emon/emontx/power1 115
> 2017-11-02 07:27:01,610 INFO RFM12Pi Publishing: emon/emontx/power2 16
> 2017-11-02 07:27:01,613 INFO RFM12Pi Publishing: emon/emontx/power3 0
> 2017-11-02 07:27:01,615 INFO RFM12Pi Publishing: emon/emontx/vrms 24906
> 2017-11-02 07:27:01,617 INFO RFM12Pi Publishing: emon/emontx/rssi -77
> 2017-11-02 07:27:01,619 INFO RFM12Pi Publishing: emonhub/rx/10/values 115,16,0,24906
> 2017-11-02 07:27:01,621 INFO RFM12Pi Publishing: emonhub/rx/10/rssi -77
> 2017-11-02 07:27:01,624 DEBUG RFM12Pi 71807 adding frame to buffer => [1509607621.599975, 10, 115, 16, 0, 24906, -77]
> 2017-11-02 07:27:01,626 DEBUG RFM12Pi 71807 adding frame to buffer => [1509607621.599975, 10, 115, 16, 0, 24906, -77]
> 2017-11-02 07:27:01,627 DEBUG RFM12Pi 71807 Sent to channel(end)' : ToEmonCMS
> 2017-11-02 07:27:04,320 DEBUG RFM12Pi 71808 NEW FRAME : OK 16 95 6 145 14 (-66)
> 2017-11-02 07:27:04,323 DEBUG RFM12Pi 71808 Timestamp : 1509607624.32
> 2017-11-02 07:27:04,324 DEBUG RFM12Pi 71808 From Node : 16
> 2017-11-02 07:27:04,325 DEBUG RFM12Pi 71808 Values : [1631, 3729]
> 2017-11-02 07:27:04,326 DEBUG RFM12Pi 71808 RSSI : -66
> 2017-11-02 07:27:04,327 DEBUG RFM12Pi 71808 Sent to channel(start)' : ToEmonCMS
> <snip>
> 2017-11-02 07:27:07,310 DEBUG RFM12Pi 71809 NEW FRAME : OK 10 111 0 15 0 0 0 90 97 (-77)
> 2017-11-02 07:27:07,313 DEBUG RFM12Pi 71809 Timestamp : 1509607627.31
> 2017-11-02 07:27:07,314 DEBUG RFM12Pi 71809 From Node : 10
> 2017-11-02 07:27:07,315 DEBUG RFM12Pi 71809 Values : [111, 15, 0, 24922]
> 2017-11-02 07:27:07,316 DEBUG RFM12Pi 71809 RSSI : -77
> 2017-11-02 07:27:07,317 DEBUG RFM12Pi 71809 Sent to channel(start)' : ToEmonCMS
> 2017-11-02 07:27:07,319 INFO RFM12Pi Publishing: emon/emontx/power1 111
> 2017-11-02 07:27:07,321 INFO RFM12Pi Publishing: emon/emontx/power2 15
> 2017-11-02 07:27:07,323 INFO RFM12Pi Publishing: emon/emontx/power3 0
> 2017-11-02 07:27:07,325 INFO RFM12Pi Publishing: emon/emontx/vrms 24922
> 2017-11-02 07:27:07,327 INFO RFM12Pi Publishing: emon/emontx/rssi -77
> 2017-11-02 07:27:07,330 INFO RFM12Pi Publishing: emonhub/rx/10/values 111,15,0,24922
> 2017-11-02 07:27:07,332 INFO RFM12Pi Publishing: emonhub/rx/10/rssi -77
> 2017-11-02 07:27:07,334 DEBUG RFM12Pi 71809 adding frame to buffer => [1509607627.310431, 10, 111, 15, 0, 24922, -77]
> 2017-11-02 07:27:07,336 DEBUG RFM12Pi 71809 adding frame to buffer => [1509607627.310431, 10, 111, 15, 0, 24922, -77]
> 2017-11-02 07:27:07,336 DEBUG RFM12Pi 71809 Sent to channel(end)' : ToEmonCMS
> 2017-11-02 07:27:07,407 INFO emoncmsorg sending: https://emoncms.org/input/bulk.json?apikey=E-M-O-N-C-M-S-A-P-I-K-E-Y&data=[[1509607621.599975,10,115,16,0,24906,-77],[1509607624.320342,16,1631,3729,-66],[1509607627.310431,10,111,15,0,24922,-77]]&sentat=1509607627
> 2017-11-02 07:27:07,573 DEBUG emoncmsorg acknowledged receipt with 'ok' from https://emoncms.org
> 2017-11-02 07:27:07,575 INFO emoncmsorg sending: https://emoncms.org/myip/set.json?apikey=E-M-O-N-C-M-S-A-P-I-K-E-Y
