WVC inverter - 430MHZ radio protocol description
Hello,
I came to your forum reading this very long article https://community.openenergymonitor.org/t/wvc-inverter-mqtt-data-logging-for-all-versions-of-inverters/12352/1
I am wondering if (in the meantime) exists a document that describes the 400MHz radio protocol used by WVC inverters and if ultimately there is a way to dynamically limit their production based on the load measured by an Energy Meter.
My idea is to create a scalable system made of WVC inverters connected to a 48V battery. I already use a WVC inverter connected to a 48V battery, but configured with a fixed production threshold.
Thank you in advance for any hint, link or suggestion
Enzo
(Italy)
Should able to, but never tried.
There’s a list of how to modify power output in the above mentioned thread, but it will not be a very quick ramp up or ramp down of the inverter, as it needs around a 1/2 second to respond.
