Yeah I thought so too, so there is a PR incoming…
Please excuse the form spam while I reply to myself - this works as intended - kinda.
It does keep the log following the output - however that does make it pretty impossible to scroll back up the log.
So right now - this looks very cool - but its not quite as functional as I would like…
I thought that it already did?
Edit, cross posted with Andy
I think what I actually need - is the auto-refresh button, on the update log…
Are you just referring to windows? The log files do scroll on Linux. I would like to make the log window viewer for the emonPi update log window persistent, currently when navigating away from the page after updating the log window disappears which makes future debugging tricky. As I mentioned previously a one button press to save or copy a log file would be super useful for user support.
@glyn.hudson - the autoscroll works on the emoncms.log (if its enabled) but the autoscroll isn’t working (for me) on the update emonPi window.
I have made it sort-of work, although it bizarrely didn’t scroll right very end (it stops a few lines up from the end at the moment) although I could probably fix that.
So - please confirm that this window auto-scrolls for you (without you actually scrolling it yourself)
Just tested; you’re right. It doesn’t auto scroll. I;m sure it used to at some point in the past! It would be nice if it did autoscroll…
Fixed - PR#587
Yeah, working great for me. Nice work ![]()
PR has been merged.
https://community.openenergymonitor.org:/uploads/default/original/2X/a/ac79a38c56d8eb4921893b1db6284995bdd0d320.webm
