Hello,
maybe someone wants to do that as well …
i have a ambient weather station, and wanted to integrate that into emoncms …
as i know my weatherstation: WS-2902A is providing weatherdata via livedata.html, but i wanted that it is writing directly to it …
and as i know it is writing data to wunderworld and ambientweather.com.
so, i decided to write it once to ambientweather my account and will use the wunderworld weather to send this data to my emonpi.
is working smooth
1.) changed the DNS name for “rtupdate.wunderground.com” to IP address of emonpi on my local DNS server (on almost every router you can define your own host names + ip)
2.) configured in OBSERVIP the wunderground account with username + password (this you need to adjust in the php script - see below, you can take whatever you want, as it will not be sent to wunderground in real)
3.) wrote a php script and put it to a new folder on emonpi: /var/www/html/weatherstation and named the php script: (adapt IP to your
updateweatherstation.php (i formated the values to mm, m/sec, °C)
here the file:
<?php
// Parse the wunderground packets sent from the ObserverIP
// The ObserverIP does not provide heat index data in its packet, this will calculate it
// Formula from NOAA http://www.wpc.ncep.noaa.gov/html/heatindex_equation.shtml
function heatindex($T, $RH) {
$HI = -42.379 + 2.04901523*$T + 10.14333127*$RH - .22475541*$T*$RH - .00683783*$T*$T - .05481717*$RH*$RH + .00122874*$T*$T*$RH + .00085282*$T*$RH*$RH - .00000199*$T*$T*$RH*$RH;
return round( $HI, 1 );
if ( ($_GET["ID"] == "<USERNAME-FOR-WUNDERGROUND>") && ($_GET["PASSWORD"] == "PASSWORD-FOR-WUNDERGROUND") ) {
$heatindex = heatindex($_GET['tempf'], $_GET['humidity']);
$data = array(
'outTemp=' => (($_GET['tempf'] - 32) / 1.8),
'outHumidity' => $_GET['humidity'],
'dewpoint' => (($_GET['dewptf'] - 32) / 1.8),
'windchill' => (($_GET['windchillf'] - 32) / 1.8),
'heatindex' => (($heatindex - 32) / 1.8),
'windDir' => $_GET['winddir'],
'windSpeed' => ($_GET['windspeedmph'] * 0.44704),
'windGust' => ($_GET['windgustmph'] * 0.44704),
'rain' => ($_GET['rainin'] * 25.4),
'dailyrain' => ($_GET['dailyrainin'] * 25.4),
'weeklyrain' => ($_GET['weeklyrainin'] * 25.4),
'monthlyrain' => ($_GET['monthlyrainin'] * 25.4),
'yearlyrain' => ($_GET['yearlyrainin'] * 25.4),
'radiation' => $_GET['solarradiation'],
'UV' => $_GET['UV']
// 'inTemp' => (($_GET['indoortempf'] - 32) / 1.8),
// 'inHumidity' => $_GET['indoorhumidity'] * 25,4),
// 'barometer' => $_GET['baromin'],
// 'txBatteryStatus' => $_GET['lowbatt'],
// 'softwaretype' => $_GET['softwaretype'],
// 'action' => $_GET['action'],
// 'realtime' => $_GET['realtime'],
// 'rtfreq' => $_GET['rtfreq']
$payload = json_encode($data);
//API URL
$url = 'http://<YOUR-IP-FROM-EMONPI>/emoncms/input/post?node=weatherstation&fulljson='.$payload.'&apikey=<PUT_HERE-YOUR API_CODE>';
$result = file_get_contents($url, false);
echo 'result:'.$result;
} else {
header('HTTP/1.0 401 Unauthorized');
echo 'wrong data provided - failure';
die();
