F1p
(Phil Thomson)
21
@Dan_Nichols -
Tobias has been active on the decode community too - but is yet to add full Zone 2 compatibility.
Good spot, I was going to mention the Telnet interface in the last post but you have done a due diligence check!
borpin
(Brian Orpin)
22
One alternative to using MQTT within HA directly would be to use the Node-RED addon to translate the MQTT data to sensors.
F1p
(Phil Thomson)
23
Hi @Dan_Nichols,
I have added your MQTT base path as a custom field as per your feedback, in addition to a bug fix found by another user:
Version 3.1 is published and can be updated via the web portal:
Timbones
(Tim)
24
FYI: I’ve split this out into it’s own topic.
