I’ve just started using the new emonSD-03May16 image and I had decided to use wired ethernet for a while so I downed the wlan interface to ensure the Pi would only use the ethernet port. So I was surprised a few minutes later to find wlan was up again, which I tracked down to the wifi-check script in /home/pi/emonpi.
When I reviewed the script, I found it has logic to check if the wired ethernet was active before it enabled the wlan interface, but this code was commented out.
Any ideas why?
Cheers
Ian
